Cannondale SISL2 compatibility
Bely
by Bely
Hi does anyone know if the SISL2 crank from cannondale is compatible with campy SR 11? I am thinking of giving it a go but am unsure if it will be compatible
Thank you!
Current
Festka Scala | Pego Respo | English V3 | Colnago EPS Erik Zabel | Colnago V4rs
Incoming
CamW
by CamW
Yup, its compatible. You can get 130 or 135mm spiders and the spidering should work perfectly fine too.
Sweetbabyj45
by Sweetbabyj45
I have the sisl2 running with my SR with no problems... 110 spider
Sent from my Nexus 5X using Tapatalk
KimJaeCheon
by KimJaeCheon
yes i use same component you written
