Need help to find correct headset - Cannondale CX9
Hi,
I have bought a used Cannondale CX9 (made 2009), when I took of the fork to cut it a bit, the bearings fell apart.
On one of the bearings it says "TH Industries 1-1/8 45-45" or something like that. Both bearings have the same outer- and inner diameter.
Here are some pictures:
Can anyone link to a headset kit that contains everything I need?
Please let me know if you need more information.
You need a 45/45 'campy' style headset.
For example, an FSA Orbit CE - http://www.chainreactioncycles.com/fsa- ... p-prod9069
stormur wrote:except lower bearing which is specific Cannondale
What do you mean? From what I can tell the upper and lower bearings have the exact same size.
The bearings in link @CrossRob suggested have the same label as mine "TH Industries 8 1/8 45-45"
you're right - my mistake . it's "straight" steerer, not tapered . For tapered you need specific ...
Another thing is "height" of "campy 45*" - I found 3 different height from 3 different suppliers... difference was to have fork grinding headset or not to have, so best is go to any LBS with old bearing and compare.
Or find some "cannondale expert shop" - they have original spares - it's best solution.
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
