110BCD, 2015 "22" model. Need to replace outer chainring from 46 to 52.
Q is (hidden bolt) other manufacturers chainrings compatibility ?
Sram Red exogram : chainrings option
- prendrefeu
- Contact:
Any chainring with 110BCD will be fine, either remove the chain catcher pin or rotate the chainring 180°.
Some chainrings are thicker than others, make sure your spacing is correct to keep the chainring in parallel.
