Seat tube design of Trek Domane SLR
I'm considering this bike as my next bike, so I'm really interested in the durability of the new design.
Won't the new pivot points create more stress at the very end of the tubes (since they have some more leverage now)?
I'm sure someone with an engineering background can elaborate on this?
But I could be wrong
Trek has lifetime warranty on their frames, I wouldn't worry about it.
Your design has solid constraints at 2 points along the cantilevered beam. Their design has 5 degrees of constraint at 2 points and a third constraint that is movable along the cantilevered beam to adjust the rate of the beam. That additional constraint you apply at both ends will increase the rate dramatically.
That isn't to mention the fact that the holes you drilled in the CF seat post took a significant amount of the inherent strength out of the post by taking what was single continuous fibers and chopping them up.
pyrahna wrote:Your design has solid constraints at 2 points along the cantilevered beam. Their design has 5 degrees of constraint at 2 points and a third constraint that is movable along the cantilevered beam to adjust the rate of the beam. That additional constraint you apply at both ends will increase the rate dramatically.
There are a lot to improve regarding details of my seat post, no doubt about it. What I am referring is the concept of the design.
kai-ming wrote:pyrahna wrote:Your design has solid constraints at 2 points along the cantilevered beam. Their design has 5 degrees of constraint at 2 points and a third constraint that is movable along the cantilevered beam to adjust the rate of the beam. That additional constraint you apply at both ends will increase the rate dramatically.
They're not the same at all AFAIK. Yours does not decouple the seattube from the rest of the frame. Also, your idea was to reduce the net tension capability of the beam significantly in order to induce strain. Pretty much you probably violated both the strain allowable and the tension factors of safety for the design. On top of that, you introduce issues like interlaminar shear during bending and stress risers from your drilling.
Not a great engineering direction.
Anytime i have an option at work to not drill into carbon fiber, I take it.
Didn't learn after all these year.
Drilling is the easiest way for me to make the post more flexible and lose some weight at the same time. My post not just survive but still works great now after years of battering.
Your design may work for you, I have no idea what you weigh or where you ride. But it sure as heck won't work for such a wide array of conditions a Domane may see (cobbes, big 230+ lb guys, etc etc).
Trek copied part for part EEcycles' Brake design Trek/Bontrager never responded to my inquiry on that one. Done with them.
IDENTITAIRE wrote:Trek copied part for part EEcycles' Brake design Trek/Bontrager never responded to my inquiry on that one. Done with them.
Craig and Bontrager are using the same open patent. Designs aren't exactly the same..
