Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Thu Feb 26, 2004 5:20 am
Hello,
I need your advice. My Easton EC70 carbon post seems to have seized to the seat tube of my Dean Ti. I can't seem to budge it - even with a mallet. I think there is an aluminum sleeve in the seat tube.
Anyone experienced this before? What can I do to loosen the post? Would WD-40 work? Help!
 Post subject:
PostPosted: Thu Feb 26, 2004 6:23 am
My wr carbon post bonded to my aluminum insert in my ONCE frame.......can't get it out of the insert!!
PostPosted: Thu Feb 26, 2004 6:25 am
Rippin wrote:
Hello,
I need your advice. My Easton EC70 carbon post seems to have seized to the seat tube of my Dean Ti. I can seem to budge it - even with a mallet. I think there is an aluminum sleeve in the seat tube.
It happened to a buddy of mine, but with a cheaper post and frame. After some serious effort he took it to a shop and had them do it.
Anyway, I'll tell you what a maintenance book says to do:
1) Remove seatpost binding bolt (obviously!)
2) Squirt penetrating oil all around the post so it will seap into the tube. If you're serious about it, you should also remove the bottom bracket and squit oil in from that end. Let it sit overnight.
3) Next day, stand over the post and apply twisting force to the saddle.
4) If step three doesn't do it, you must sacrifice the post.
5) remove saddle, clamps, etc. Put the post in a vice (thus ruining the post forever). Apply twisting force to the frame around the post, grabbing the frame from the extreme ends around the post - and realizing you can possible even bend the frame (but It's a Ti frame, they're very resilient). You should hear a loud "pop" if it releases.
6) if THAT fails, go to a machine shop. It can only be reamed out .. $$. I guess if it's a Ti frame it's worth doing that.
Good luck!
 Post subject:
PostPosted: Thu Feb 26, 2004 6:59 am
Hey Rippin.. and adendum here.
Instead of removing the BB .. Remove the bottle cage holder screws. Use WD40's supplied "straw" to squirt oil in. What a freekin pain in the arse to remove the cranks and BB for that side of the post! :shock:
 Post subject:
PostPosted: Thu Feb 26, 2004 7:02 am
Thanks all for those suggestions. I'll give it a try tonight. Any more comments from others?
How could carbon seize to aluminum or titanium??
 Post subject:
PostPosted: Thu Feb 26, 2004 11:28 am
Administrator
:idea: Try some soft tapping with a plastic hammer on the seattube. :idea: It will take you quite some time, but usually this will work!
Good luck!
Follow me on twitter. I try to be interesting ;)
On Facebook!
 Post subject:
PostPosted: Thu Feb 26, 2004 2:12 pm
Dont't know, but I have a carbon post in an Al frame and I have to change the saddle height regurarly. Some months ago, the post was nearly seized, I asked a mechanic what to do and he told me to put a little bit of grease between it. A month later the seatpost went lower. I went to my bike shop and he put some black, 'dirty' grease on the post.
 Post subject:
PostPosted: Thu Feb 26, 2004 9:11 pm
did you grease it? grease bonds carbon to aluminium.... you have to very carefull with carbon as its easily penetrated....
My Place :-)
 Post subject:
PostPosted: Thu Feb 26, 2004 9:13 pm
mite be worth removing that before it ends up seized!!! its only a 30 min job @ the most :wink:
My Place :-)
 Post subject:
PostPosted: Thu Feb 26, 2004 9:28 pm
i just saw this post, so if it doesn’t budge with lateral leverage on the seat or the end of the post, and the insert is aluminum.... carbon post.... its toast.
you could try heat and cold but the battery between the carbon and aluminum has welded them together to a point that the post will most likely not be salvageable when you do get it out.
never never put carbon and aluminum together.
if the ti frame builders were wise, they would use an epoxy/glass shim instgead of aluminum bacause soem many people like to put carbon posts in there.
www.crumptoncycles.com
 Post subject:
PostPosted: Thu Feb 26, 2004 9:42 pm
you lost me on this one..... im sure there are 1000's & 1000's ov al frames wiv carbon posts in them?
My Place :-)
 Post subject:
PostPosted: Thu Feb 26, 2004 10:37 pm
you are correct, and there are 100's of them getting stuck as we speak. its a bad idea. if its not maintained it will eventually get stuck.
if that were not true... then this discussion would not be happening.
 Post subject:
PostPosted: Thu Feb 26, 2004 11:04 pm
Is there anything that can be done (anti-seize, etc.) that can prevent Alum and a carbon post from seizing?
 Post subject:
PostPosted: Thu Feb 26, 2004 11:24 pm
keep it clean and greased. pick a post that has a thicker clear coat. the thinner the clear, the closer home the reaction.
 Post subject:
PostPosted: Thu Feb 26, 2004 11:43 pm
The environment can make a big difference. I had a number of aluminum lugged carbon bikes fail on me from galvanic corrosion when I lived in Hawaii and was in salty air all the time - a couple of them in less than 6 months, but I knew people with the same frames that lived in the interior of the US that never had any problems.
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], Juanmoretime and 55 guests
There are no new unread posts for this topic. Seized Tune Mag 170?
TiG
12
578
Tue Apr 23, 2013 11:18 am
TiG View the latest post
There are no new unread posts for this topic. My first post, I just bought a frame.
gamedic
18
1938
Thu Jun 21, 2012 5:19 am
cpt000 View the latest post
There are no new unread posts for this topic. Compatibility - Ritchey SL carbon post and SL Flite gel
glowder
Mon Jun 25, 2012 2:43 pm
glowder View the latest post
There are no new unread posts for this topic. MC053 Carbon Seat Post Conversion - Saved 111g
lo5707
30
2257
Mon Mar 11, 2013 11:06 pm
lo5707 View the latest post
There are no new unread posts for this topic. Selle Italia Carbon Monolink post - stripped nuts?
richard@lbrc.org
Mon Apr 22, 2013 1:46 pm
Butcher View the latest post
It is currently Fri May 24, 2013 10:06 am
