Kask helmets - fit
HaakonJohansen
by HaakonJohansen
Hi there everyone. Does anyone know if Kask Mojito or Kask Vertigo 2.0 comes with optional side padding? I've currently only tried the Mojito, which was really comfy, but the shape is a bit too round for my head. Would extra side padding be a safe way to fix this problem, or should I not consider this helmet because of the fit? Also, does anyone know how the fit of the Vertigo is compared to the Mojito?
beanbiken
by beanbiken
I have the Mojito and it didn't (Australia) come with any additional padding. I haven't tried the Vertigo so I can't help you there
BB
Coffee & carbon
llhh
by llhh
One more thing - it would make sense to try at least Mojito with your eyewear on. At least for me the Mojito is super good fit and excellent helmet overall but it's side plastic bits interfere with Jawbone side arms to an extent that the glasses come off when looking back... which is super annoying :cry:
Parlee Z1 Super Record
Dogma F Red AXS
jdecraene85
by jdecraene85
I have the Vertigo and the Protone.
Unfortunately for you neither have optional sidewall padding.
For me, there is no other brand that even comes close to the comfort of my Kask helmets.
Depends on your head shape of course.
If I recall correctly, people with a more round head are generally better off with brands like Giro.
HaakonJohansen
by HaakonJohansen
jdecraene85 wrote:I have the Vertigo and the Protone.
I guess Giro is out of the question then, as the Mojito is already too round for me. Hope I'll find a local shop who sells the Vertigo though, so I'll be able to see if it's better fit for me.
fignonsbarber
by fignonsbarber
No, it's the opposite. Giro and Specialized fit oval heads very well. Kask,Met are for round heads.
ryanw
by ryanw
My 2016 model didn't come with any extra padding.
IG: RhinosWorkshop
coppercook62
by coppercook62
protone fit my head best out of any helmet I have ever bought. Peoples heads are not the same so it will vary.
1415chris
by 1415chris
I have Giro Aeon, Synthe and Kask Infinity.
In terms of the fit all of them are ok with the Kask being more comfy for my big-ish head.
But that comes to indywidual fit and preferences.
What you can definitely say is that Kask put more attention into finishing touch.
Bigger dial (easier adjustment), small foam inserts where the back of the helmet comes to contact with your head and soft leather (I think) part of the strap under your chin. Small things, but when put together make a difference. And for those for whom it matters, it's made in Italy.
dcpdpayne
by dcpdpayne
At least for my head Kask helmets fit in much the same way as Specialized helmets.
As for using padding to take up extra room in the helmet, I'd stay away for trying to do that. You want your helmet to "fit" without doing too much to its natural shape. In a crash a helmet that fits loosely, or that has had to have extra padding added to make fit, will move about. This could reduce its protective ability, especially in a multi-impact situation.
