Suggestions for a light, 31.6 seatpost with < 25mm setback?
loudtiger
by loudtiger
Hi,
I'm looking for a 31.6 seatpost with 15-20mm setback. Haven't seen too many of these. Most setback seatposts are 25mm. Any suggestions? I noticed zipp and control tech both have one.
Thanks!
GT56
by GT56
Ritchey Superlogic Link Flexlogic Carbon Seatpost - Matte UD Carbon
sd5500
by sd5500
Match your stem, and adjust your seat 5mm
Raineman
by Raineman
+1, or if you can't move the saddle forwards 5mm you could go for an inline post and move the seat 15mm back.
ebsilon
by ebsilon
USE Alien Carbon is a great choice - but offset is only 10mm though.
Nice weight, price and quality
[IMG]
http://www.ultimatesportsengineering.co ... k=C9YNpV_X[/IMG]
http://www.ultimatesportsengineering.com/use-components/seat-posts/alien-carbon
Speed of Lite
Rick
by Rick
Thomson Masterpiece 0 setback, or Thomson Masterpiece with 16mm steback
Briscoelab
by Briscoelab
Also, the Enve 0 is really 5mm offset.
Syntace P6 hiflex is technically a 0, but allows a LOT of aft adjustment.
Pro vibe are 20mm, specialized makes some 20mm (if that would work on your bike).
Thomson works and looks good on a compact frame. I think the setback Thomson looks wonky on a trad frame.
Mep
by Mep
Mcfk has a 20mm offset seatpost
bikerector
by bikerector
I've had good experiences with the VCRC seatposts. Carbon, 17mm setback, 221 grams at 350mm long.
http://www.vcrcbike.com/VCRC_Alpha_Carb ... pha316.htm
RyanH
by RyanH
If you're on a budget, I have an Oval Concepts one I can sell you for cheap. It was 180g-ish uncut at 350mm and 15mm setback with boat anchor hardware. Swapping lighter yokes brought it down to 155ish.
Wookski
by Wookski
Mep wrote:Mcfk has a 20mm offset seatpost
+1 best seatpost on the market, do it right and you won't have to upgrade later
duvivr6
by duvivr6
Deda Superleggero RS 12mm setback
