How do you feel about suspension/ damping?
- wheelsONfire
This fellows is hardly something new!
http://www.cyclingnews.com/news/canyons ... road-bike/
But how do you guys feel about it?
Does it peak some sort of interest or do you instantly run in to retrogressive mode?
EDIT:
https://www.youtube.com/watch?v=xe9wh7cXLx4
EDIT:
Bikes:
Open *UP* (2016.04.14)
On a road bike? About as useful as disc brakes
Agreed. The biggest advance in road bike suspension was by far the use of air filled tires instead of solid rubber. Everything else since pales in comparison and generally has a cost, either in terms of weight or complexity, that far outweighs the benefit. Get the frame right, in terms of shape, materials, layup structure etc, and call it good. Leave the suspension to the off-roaders and freeriders.
I like the idea of suspension on a road bike and I am surprised that it hasn't been developed more thoroughly.
I guess the big question is "where to put it". My most comfortable saddles have utilized a damping layer or flexible shells or rubbery connection points which provide damping, just not in the frame specifically.
Putting the damping in the frame usually implies some rubbery componet that then negatively affects stiffness or handling. But I am all for them continuing to try new ideas.
I'm all for new ideas too but I don't feel I need suspension on a road bike, and I ride a lot of very rough roads.
As a long time mtber I love suspension.. The current designs are amazing... But have no place on a road bike.. I love the simplicity of not having the additional pivots bearings/swing arms /droppers/ blah blah for maintenance.
Unless you live on cobbles... There is really no need..those comfort designs are enough via shaping and material manipulation. Maybe some concrete pills required...
Only way it is accepted by the hardcore roadies if it is zero weight/drag gain.. And no efficient loss in any circumstances... Might as well have that perpetual motion machine
Sent from my SM-G900I using Tapatalk
