Im looking for a water bottle cage with a mounting bracket that allows me to use a larger water bottle. All the cages ive seen come with the screw holes in the middle of the cage. I am looking for one that has the screw holes near the top of the cage, that way the bottom of the cage sits lower on the downtube.
I ride a 47cm bike that only has one bottle boss on the down tube, and the biggest bottle I can fit is only 20oz. Any bigger, and the top tube will get in the way when trying to put the bottle in the cage.
Bottle cage bracket question
- Moderator
Custom drill a plastic cage?
Using Tapatalk
Arundel Mandibles have two different mounting positions (4 holes) so you could place them lower on your frame. Their Sideloader and Other Sideloader are also great alternatives for use in compact frames.
