Light weight 25.4mm post with setback
Shogunade
by Shogunade
FSA SLK 25.4 seat post.
ENVE
Cannondale C2
Cannondale C3 (Alloy)
Sacke
by Sacke
Thomson makes a 25.4mm post too. With no setback though...
I kept the carbon save post on the new Supersix Evo, but running my Bontrager Paradigm XXX carbon rails pushed about 5mm beyond the max limit line.
Not feeling great about it, but the Enve seatpost is more expensive than a new saddle, so taking the risk at the moment.
Not enough options out there for sure.
Sent from my HTC One_M8 using Tapatalk
ourmanflint
by ourmanflint
Hylix also do a zero setback post, very light at 131g.
logy
by logy
I am going to cut down the Save post and rum a J and L carbon cradle and ax lightness yokes. Just need some m5 ti bolts and it is done. Need a setback post.
prendrefeu
by prendrefeu
ourmanflint wrote:Hylix also do a zero setback post, very light at 131g.
Subject line. :roll:
ryanw
by ryanw
Bringing this one back from the dead...
Looking for a lightweight 25.4mm seat post too.
Weighed my C2 post and it came in at 236g. I've not cut it, but would rather something under 200g to start with.
Any new posts on the scene?
IG: RhinosWorkshop
DonW
by DonW
I've got a new (well, mounted) ENVE seatpost, 25.4 with the setback.
I'd sell it to you for what I bought it for at shop cost - I believe $175? Or something like that.
Still not too many 25.4 options now than a few months ago, unfortunately. Probably since Cannondale is the only one doing it.
nonamed
by nonamed
DonW wrote:I've got a new (well, mounted) ENVE seatpost, 25.4 with the setback.
Can You confirm the weight of Enve seatpost? It is 400mm length?
I got new Save Carbon seatpost - 350mm and 20mm setback. My weighs 198g.
I want to cut the last 5cm to remove Di2 alu insert for battery but I wonder how much grams I will save. Maybe it is not worth it :?
evan326
by evan326
Best option is the hylix from ebay. 143g for $69
Sent from my SAMSUNG-SM-G935A using Tapatalk
DonW
by DonW
Yep, 400mm length.
Away on vacation for a bit, but I'll have a weight (incl. hardware) for you guys in a bit.
FWIW, the SAVE seatpost isn't much heavier IIRC. It's not an upgrade I would make if you already had it. If you have the heavier C2 carbon one, then yes, upgrading to an ENVE might make sense.
Hylix is a great option as well, but no setback...
ryanw
by ryanw
Heard that hylix are a bit iffy with regards to longevity... They're also all sold out on eBay.
IG: RhinosWorkshop
evan326
by evan326
They're back in Stock on ebay now. I broke mine, only because I'm stupid. I can still sit on it while testing out components while I wait for my replacement.
niklasp
by niklasp
evan326 wrote:They're back in Stock on ebay now. I broke mine, only because I'm stupid. I can still sit on it while testing out components while I wait for my replacement.
They get kind of mixed reviews also.
I need offset too I guess. Im 184 tall.
Miller
by Miller
DonW wrote:Still not too many 25.4 options now than a few months ago, unfortunately. Probably since Cannondale is the only one doing it.
Saw a review of a Focus Paralane the other day and noticed that it's specced with a 25.4 post so not just Cannondale now.
ryanw
by ryanw
I think I'm going to bite the bullet and buy the Cannondale Save seatpost (same as one pictured above).
Once cut to length and heavy Di2 bung removed, should be around 160g I hope... Shame it's £90 over here in the UK.
IG: RhinosWorkshop
