New Zipp carbon stem and seatpost
mariovalentim
by mariovalentim
This flew under the radar for me, the design of both is very close to Enve.
The stem is sexy and the weight is pretty competitive - 123g in 100mm.
The seatpost is cool but I never had luck with one bolt systems :/
http://www.bikerumor.com/2016/04/06/zip ... -seatpost/
NiFTY
by NiFTY
123g in 100mm is aluminium weight, but it'll be 3 as much. I have 2 ritchey super logic seatpost which are one bolt and have never had slippage.
spud
by spud
stem only goes to 120mm.
jeffy
by jeffy
much harder top get angle 'just right' with one bolt clamp.
spartan
by spartan
i bought the new bony xxx stem. brilliant design. the top part flexes under load. solid design
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
F45
by F45
Heavy stem and no 17. Maybe they are trying to compete with PRO in stiffness.
mariovalentim
by mariovalentim
F45 wrote:Heavy stem and no 17. Maybe they are trying to compete with PRO in stiffness.
it's about the same weight of an Enve Road stem/Ritchey Superlogic C260 and same angle offering of those and 3T too
Zigmeister
by Zigmeister
Pro Carbon stem isn't as stiff as most stems, plus it isn't the lightest. OTOH, I've never had an issue with any stem stiffness, consider myself a sprinter. Along with Pro UD T800 carbon bars, makes for a stiff cockpit.
The weight of the Zipp SL and new stem, stiffness, seems like a good setup though. Oh, also, the Pro Stem you can get in -10, which I run.
-17 is kind of silly IMO, and -6 is OK for many, but wish there were more options for -10 stems on the market, that is a really good compromise for not just fit, but the look of the cockpit setup.
fh8425
by fh8425
hoping Zipp will do a 10 degree ..
wingguy
by wingguy
Zigmeister wrote:Pro Carbon stem isn't as stiff as most stems, plus it isn't the lightest.
The Pro Vibe Sprint carbon stem is. In the Fairwheel test it was best in test for pure stiffness with clear daylight between it and everything else. Of course, the Zipp SL Sprint wasn't in that test and it is quite similar in design.
Now the SL Speed is supposed to come in a little under that for pure stiffness, but with a good balance of STW.
mimason
by mimason
Zig, agree with your post. I wish there were -12 stems but the -10 Pro is also very nice. I passed up on the carbon and just got the alu vibe. Its stiff and cheap and works. That with the carbon Pro bar is a good setup.
On topic, i like these immediately but wrong rise angle for me too.
eric01
by eric01
Carbon stems are curious. Sure they look cool. But if you consider the price/performance/stiffness/weight equations... are they really better than alloy ones?
I can see the carbon seatpost benefits. I too have a Ritchey Superlogic. Brilliant. 140-ish grams in a 27.2 size. I know there's lighter, but they're more expensive.
wingguy
by wingguy
I used to have an Enve carbon stem on my road bike for the bling factor but when I changed length and angle I went to an alloy ARX Team that's the same weight and haven't noticed any difference.
Of course I still have an Enve MTN stem on my mountain bike for the bling factor - and it does that job very well :P
mariovalentim
by mariovalentim
eric01 wrote:Carbon stems are curious. Sure they look cool. But if you consider the price/performance/stiffness/weight equations... are they really better than alloy ones?
I agree, it's much more the bling factor than any added benefit over a good aluminium stem. To quote the Fairwheel blog:
Carbon Fiber vs. Aluminum: – Carbon fiber stems don’t offer the weight savings that, say, carbon fiber rims do. There’s a reason for this: stems are regularly stressed in three ways: bending, torsion and shear. In other words, the stresses in a stem are nearly isotropic (uniform in all directions). Carbon fiber is highly anisotropic (stiffer/stronger in one direction than in the others). When you try to lay up anisotropic carbon to deal with isotropic stresses, you end up with what engineers refer to as “black aluminum,” or pseudoisotropic carbon–and a weight that’s very close to an aluminum stem.
There may be other advantages to a carbon stem; vibration damping is one that is often put to the forefront of the debate. It’s true that composite structures generally damp vibration better than metallic ones, and there may be real-world damping benefits to a carbon stem. One way to test stem damping would be to wire an accelerometer to the stem and then strike it gently with a hammer, reading the accelerometer data to see how quickly the vibrations dissipated. This ring-down test may be on the Fairwheel menu for a future article, but is outside the scope of this test.
DMF
by DMF
Started out on the old Zipp SL145 stem, for the bling. Totally blown away by the stiffness, that was apparent from the first redlight sprint. Previous stem to that was a USE Race and before that a Thomson X4, not exactly what you'd call noodles. Been on PRO Vibe Sprint, 3T Integra Ltd and PRO Missile since then.
Never going back to anything alloy stem wise, ever again.
Try this, stand in front of your bike, grab the front wheel between your knees, grab the hoods and tug/rock the bars back, forth and sideways. Sure some of the flex is in the bars and some is at the steerer tube, but really observe the stem. You will see it flex, A LOT!
Now try this with some of the "sprinters choice" full carbon cockpits... it's rock solid.
