Bike of the Year Winner (£2750+)
- iliedanila
I just saw this video and there's a very interesting part in it, when that guy descends in the wet.
Just look at that front wheel
https://youtu.be/kh8ciU3wdxc?t=3m13s
I'm so happy I didn't get the Campa Bora wheels..
And I know people on this forum that have the nerve to recommend Campa Wheels over Enve (if you can believe that!!!)
- iliedanila
Lateral flex!? You can't see that? On a good piece of tarmac?
Sent from my SM-G928F using Tapatalk
Haven't been able to view this video yet but I noticed some of the pro riders at the Tour of Flanders last Sunday were using Campag Bora wheels. They didn't seem to a have an issue with "lateral flex"...
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
That kind of flex is not a problem. There are stiffer wheels than Bora of course...
- iliedanila
liam7020 wrote:Haven't been able to view this video yet but I noticed some of the pro riders at the Tour of Flanders last Sunday were using Campag Bora wheels. They didn't seem to a have an issue with "lateral flex"...
Pro riders don't have a say in the wheels they use. You know that, right?
We pay for wheels and definitely have a say in what we want for wheels.
And definitely other wheels don't flex on good tarmac with a lightweight rider on them...
- iliedanila
I will ask a friend to film me just to prove a point. I have tune schwarzbrenner 38T on my bike.
If there was as much flex as you think there is and it's a problem like you think it is the guy would be on his ass when the massive deflection caused it to rub the brake blocks.
I'm a very big Weenie (100 KG+) and have zero problems with wheel deflection on BORA's (50mm Ultra Tub's). I run my brake blocks very tight front and rear and no rubbing.
I can't say the same of my last set of ENVE's Rim brake wheels (3.4's on Tune hubs).
If you look at the TOUR testing Bora's aren't the stiffest wheels out there (however they are pretty stiff) but they are definitely stiffer than ENVE's.
If you want to Compare a set of 5.6 or 6.7's to BORA's- Yes they might be a stiffer rim - but unless you can lace them into a 2:1 hub like Campy (or i9 like a set of 3.4 Disc Rims i'm having built right now) overall they won't compete or at best will be just as stiff as Bora's - but at a significantly higher weight and Moment of Inertia.
Add 100 grams to each rim of a BORA and it would be significantly stiffer than an ENVE.
See here, the stiffness of bora 35's clincher used by Canyon. Front = excellent, Rear : rather average
http://www.roadbike.de/rennraeder/test-canyon-ultimate-cf-slx-9-0-ltd.1503348.9.htm
Have to confess : was forced to set the blocks to around 3 mm's from the rim, front and rear, otherwise, I got some rub during hard efforts out of the saddle. Not a big issue, love those Bora's, but worth mentionning.
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
Retired:
jeffy wrote:Nejmann wrote:Rain.....?
I have agreed to participate in the filming production, and will be using ESCHBACH high quality hose to simulate rain. I have also contracted a Romanian firm to sample and reproduce the tarmac used in the Cycling Plus.
I see what you did there.
