Is my math right? Aero bikes
mbrider
by mbrider
On the PR front, it would be interesting to see Matt Hayman' power numbers - to see if he had an extraordinary day or if he has always been able to put out those kind of watts for that long. From the footage I watched, he didnt seem very active in the early part of the breakaway (had a teammate that seemed to be doing more work in those stages of the break). And I def. think he profited from being in the break and seeing the cobbles in a more relaxed and controlled fashion (not having to fight for position etc.). It also looked to me as though the Orica boys were the only ones on aero bikes, maybe Katusha would be the only other team. Over the distance of the break and the fact that the Scott Foil tested very well in compliance for an aero bike, I think it meant that it gave Matt H an advantage over any other non aero bike set up. He also appeared to be the freshest of the bunch in the last ~10k, even before the sprint.
Its evidence to me that an optimized aero set up (like everyone else is saying, aero helmet / skinsuit / wheels and bike) can add up to make a slim advantage. Sometimes a slim advantage is all you need.
These guys I would guess were always traveling at speeds where aero gear makes sense (almost all run a 44 inner ring - gotta be a low gear and cadence that equals over 15mph?) And the average speed for the race was 27ish mph. probably with little variance (what was the max speed, maybe just over 40mph? and not for very long I would imagine).
Regarding the Tri Rig brake - do you have the older version, or the new one?
I have both on my TT bike. The old one is now set up with a cross style headset front brake hanger and just bare cable down to the brake. it works much better. The new one is even better still (and on the rear).
On the S3 this set up will only be used with carbon wheels and the newer style wide rim format which will increase braking even more. I am very confident that this will be an awesome front brake set up (the new one is pretty slick, and is pretty easy to wrench / set up).
Dr.Dos
by Dr.Dos
Nonsense, it's the rider and if anything, it's the tire (Conti's pro limited series is awesome, Orica's tech guy tested this stuff on our local races and raved about it, he tested wheels and pressure until material failed here as well).
Canyon was all aero, didn't help Alex though.
Miller
by Miller
mbrider wrote:Regarding the Tri Rig brake - do you have the older version, or the new one?
It's the current model Omega X set up with a cable hanger in the stem. For all its aero virtues it does not deliver braking power like a groupset caliper plus you're locked into a particular stem height and it's more hassle to work on. For me those are significant negatives for putting it on a general use road bike.
Marin
by Marin
wop wrote:stiffness of a frame is much more import
I agree with the rest, but how is stiffness supposed to help? "Power Transfer"?
dalex
by dalex
Dr.Dos wrote:if anything, it's the tire (Conti's pro limited series is awesome, Orica's tech guy tested this stuff on our local races and raved about it, he tested wheels and pressure until material failed here as well).
These are the awesome, pro limited tubulars that one cannot actually buy in a shop?
BeeSeeBee
by BeeSeeBee
Yeah, we already had a long thread about it that didn't result in any conclusions, just more conjecture: viewtopic.php?f=3&t=133901&hilit=stiffness
Dr.Dos
by Dr.Dos
Not available for us mere mortals. They come with latex inner tubes and various rubber compounds and layups depending on conditions.
Lars Teutenberg is known as aero and equipment geek for decades (he must be like 46 now). If he shows up at local races, you know it will be a damn fast finale and most primes are belong to him or his buddy. I've seen him puncture with the super fast flavor at least twice, very unlikely to happen with the regular Conti stuff.
Ailar
by Ailar
Aero is a buzzword when talking about frames. Not a single bicycle company has tested aero frames in real situations. Aero is good when you are on the first, third, fourth in the line. I haven't seen any videos of aero testing in groupetto, because that would be too expensive. There are only videos of aero bike alone, aero bike on the third position, but in grouppeto air moves much different then in the front.
So if you're not building a TT bike or planning to be in the breakaways all the time, save your money and invest in light aero wheels and buy something nice for the money that was not spent, because you skipped the "aeroframe" buzzword ;)
Cycling geek from Estonia
cobrakai
by cobrakai
Ailar wrote:Aero is a buzzword when talking about frames. Not a single bicycle company has tested aero frames in real situations. Aero is good when you are on the first, third, fourth in the line. I haven't seen any videos of aero testing in groupetto, because that would be too expensive. There are only videos of aero bike alone, aero bike on the third position, but in grouppeto air moves much different then in the front.
Sure, there is very little reason to upgrade to an aero frame if you already have a perfectly good frame. But if you are in the market for a new bike there is very little reason to not consider an aero frame if they fit well. Other than the uber expensive Venge and Madone most other aero frames are priced similarly to a manufacturer's round tube race offerings.
Krackor
by Krackor
Ailar wrote:Not a single bicycle company has tested aero frames in real situations.
Complete bullshit. Trek has not only tested their new Madone in real situations, but they have released detailed descriptions and data from their tests in the Madone whitepaper. You ignore their testing, and ignore the possibility of bike companies doing their testing but not releasing results. At best you might be able to say that you are unaware of any testing done in real situations, but if you don't know of the Madone whitepaper you can't possibly be well-informed about aero bike frames. This statement alone shows that you have no credibility.
Ailar wrote:So if you're not building a TT bike or planning to be in the breakaways all the time, save your money and invest in light aero wheels and buy something nice for the money that was not spent, because you skipped the "aeroframe" buzzword ;)
Why buy aero wheels but not aero frame? This again reveals that you're just a luddite or contrarian who doesn't want to accept a new technology, instead of making a decision based on data and logic.
Add one to the list of ignorant aero skeptics on this forum.
Ailar
by Ailar
Could you please provite that whitepaper? :beerchug:
Wheels are spinning, frames aren't.
Krackor
by Krackor
It's literally the first google result for "Madone whitepaper". Do your homework before you make such brash claims.
What's your mathematical basis for believing that the fact the wheels are spinning makes their aerodynamics matter while a frame's aerodynamics doesn't? This would be a revolutionary conclusion that turns the industry on its head if it were true. Show me your data!
AJS914
by AJS914
Wheels are turning, frames aren't.
Really? Airplane wings don't turn.
