It was comparing aero frames to aero frames, not aero to standard
Article he cherry picked/misrepresented:
http://ir.canterbury.ac.nz/bitstream/ha ... sequence=1kgt wrote:"The gains which could be made from very small modifications to the frame would be minimal compared to those which could be made through changes in position."
The bike itself accounts for only 30% of the overall drag on a cyclist [Oggiano et al., 2008], so the gains which could be made from very small modifications
This is a statement referencing the limitations placed on bicycle design by the UCI, followed up by referencing the limitations placed on a cyclist's position by the UCI, not some sweeping conclusion about the frames.
"The cyclist contributes significantly more to the overall drag on a cyclist than the frame and wheel combination, and that in order to increase the velocity of a track cyclist the focus should be on improving athlete position rather than the design of the frame or wheels."
Fortunately we have the capacity to do
both, much like how "why don't you just take a shit before you ride" is a dumb contrarian answer to someone looking to drop some weight on their bike. The bike contributes significantly less to the overall system weight than it does to the overall system aerodynamics, so why don't you go shit up some threads about that instead?
"Frame modifications contributed to only 0.3% of the total aerodynamic drag of a cyclist."
"A change to the shape of the bike frame had no significant impact on the drag."
*gasp* more cherry picking and misrepresentation from kgt?
"A change in skinsuit had a significantly greater impact on the aerodynamic drag compared to all other changes made to the equipment, and a change to the shape of the bike frame had no significant impact on the drag (<0.3%).
This low change in drag for the bike frame is likely to be due to the fact that all bikes used in this study were already optimised in terms of aerodynamics with an aerodynamic frame; a comparison between a non-aerodynamic and aerodynamic frame would likely lead to a greater change in drag."
Care to further explain your position kgt?
