9070 front derailleur trim
Delorre
by Delorre
Guys, I'm at work, so can't try it at the moment, but I have a very small 'issue' with my 9070 front mech. The limit inner and outer screws are totally well setup, everything is perfect, except, when on the small ring and 4th smallest cog, the chain almost rub on the outer face of the mech. When I shift to the 3th smallest cog, auto trim occurs and move the front mech a little to the outside. Going back to the 4th smallest cog don't induce trim, so there, everything is perfect.
Question : what is the solution to move the mech a little to the ourside? The inner limit screw doesn't have effect, I tried that yesterday. Setting outer limit screw à little more outward maybe? Or is there is a trim function like the rear mech? Thx!!
mai
by mai
put it in big chainring/big cog combination and enter adjust mode (press and hold button under junction box). then try adjust the fd trim a couple of notches. press and hold the junction button again to save.
hope that helps.
toiyuet
by toiyuet
If you want to move the mech a little to the ourside when it's on 4th smallest cog, I don't think the outer limit screw would work.
goodboyr
by goodboyr
Start from scratch and follow dealers manual to the letter. Stop flying blind and playing around.
11.4
by 11.4
goodboyr wrote:Start from scratch and follow dealers manual to the letter. Stop flying blind and playing around.
Second this. Patching a bad install doesn't make it better with 9070. It has to be done exactly according to the manual, so start over and do it correctly.
onurruno
by onurruno
You need to be sure that chain in line. That's why starting over is best solution for a smooth and flawless shifting & front trim.
Delorre
by Delorre
mai wrote:put it in big chainring/big cog combination and enter adjust mode (press and hold button under junction box). then try adjust the fd trim a couple of notches. press and hold the junction button again to save.
hope that helps.
Will try that this evening. I hope it doesn't only affect the position of the front mech when on the big ring. I've never ridden big-big I think, so I even don't know if trimming is needed or if it will mess up the current adjustment.
muntos
by muntos
I had the same problem and it was the FD not aligned with chainring.
goodboyr
by goodboyr
hope that helps.
Blows my mind that you are not taking our advice on this. You wouldn't have any of these questions or concerns if you did.
ms6073
by ms6073
Agreed. For the OP, follow the advise and click on the following link to the Shimano 9070 Dealer manual, download/print out, then turn to chapter titled 'ADJUSTMENT' beginning on page 51, and follow the setup instructions. Do this and you will not ever need to ask these questions again!
- Michael
Delorre
by Delorre
goodboyr wrote:
hope that helps.
Wow, calm down boys :lol: The install is pretty well done, no need to start from scratch, really. Tried the trim function in big/big, but 2 or 3 cliks up didn't seem to make any noticeable difference when back on the small ring. Was worth trying... The only thing I've done right now, is an 100% alignment of the front mech with the big ring. The cage was very, very slightly turned inward compared to the big ring. After the small tweak, the 'problem' is gone. Note, there was no rubbing when in the 4th cog, even under load, but the cage came a little to close to the chain to my liking. But case closed now, everything is fine 8) Thx for the advice on the cage alignement!
goodboyr
by goodboyr
Ok, then. Just out of interest, have you positioned the support bolt on the front derailleur properly? That would ensure stiffness and alignment.
Delorre
by Delorre
goodboyr wrote:Ok, then. Just out of interest, have you positioned the support bolt on the front derailleur properly? That would ensure stiffness and alignment.
Yep, I used the support bolt to put a little pressure on the front mech, also just enough to align it perfectly.
goodboyr
by goodboyr
Great. Thanks, and safe riding!
:D
