Removing Acros headset from Canyon - what parts do I need?
Hi,
I currently have a Canyon road bike with Acros Ai-70 headset. Although it works fine, the headset adds a lot of stack to the setup. I want to replace it for a 'conventional' headset assembly. Canyon offers a kit, but it has been unavailable for months. So, I am now looking of buying the parts myself.
Does anyone have experience with this? If I am correct I would need two parts:
- Headset bearing cover e.g. http://www.avt.bike/WebStore/merchant.m ... TS-14BCAPS
- Compression plug e.g. http://avt.bike/WebStore/merchant.mvc?S ... 305-HD5347
It's rather difficult to find these parts for 1 1/4 fork tubes, especially the bearing cover. I am also worried if the bearing cover would fit properly. Canyon sells a cover from Acros, but this does not seem available at the Acros site.
Thanks for the help!
Timmetje wrote:Hi,
http://www.canecreek.com/headset-fit-finder
I recommend you using cane creek headset fit finder
It suggests IS47/31.8 UPPER , IS52/40 LOWER
How do you think? I think this headset+conventional compression plug is better than Acros headset.
RickyKong wrote:Timmetje wrote:Hi,
Really sorry about that.. Cane creek recommends IS47/31.8 Upper set but they don't sell it....
Have you ever tried the giant OD2 headset & Compression plug??
Bump. Is anyone able to confirm what's what?
I currently have an Acros headset and would like to remove it and replace it with a conventional looking headset cover and compression wedge. Does anyone have a link to a headset top cover that works well with the Canyon (i.e. it's 1&1/4" and the OD is the same as the headtube)? Thanks
Not sure about matching the head-tube but the 2016 Scott Foil uses an 1 1/4" stem so a Ritchey or Syncros headset should be available.
The spec sheets list a Syncros integrated headset,
http://www.syncros.com/us/en/products/2 ... 40-Headset
but any IS headset of the following spec will work, top bearing set IS46/31.8, lower bearing set IS52/40
or check the spec with Acros, they do other headsets with a more conventional top bearing cap and carbon steerer expanding star nut and top cap.
motorapido mentioned:
However, the before mentioned spec is IS47/31.8 upper... I don't know if the difference between IS46 and IS47 would make it incompatible...
"any IS headset of the following spec will work, top bearing set IS46/31.8, lower bearing set IS52/40"
Did you get anywhere with this, looking for a headset for a Giant.
