Hi,
I am about to change the headset bearings for my 2012 CAAD10. It uses integrated bearings bur what is the correct size for top and bottom. I could of course take the current out bur I use it for my daily commute and would like not to. I have looked at cane creeks website. but there are a few options for tapered integrated headsets. Does any of you know the right size?
Thanks
Bearing size for Caad10
This should sort you out
http://qwertycycles.co.uk/collections/h ... set-hdl002
- in the industry
Have you tried the Cane Creek headset finder on their website? just enter your bike specs in the required fields and it should pop out an answer.
Using 2012 CAAD 10 stock fork I got the following results. (not saying these are correct, just what the Headset Finder is telling me.)
Upper: IS 42/28.6
Lower: IS 47/33
http://www.canecreek.com/headset-fit-finder
Upper: IS 42/28.6
Lower: IS 47/33
