Giant seat post help
tacostand
by tacostand
Can anyone help with tips to "unstuck" a Giant seat post? I bought a TCR Advanced months ago and need to make some adjustments to the saddle height but I'm so far unable to move the post up or down. The wedge that holds the post in place is stuck in place. I've removed the bolt but not able to get the wedge up to move the post. Tips? I'll take it into the shop if I'm not able to figure it out but hoping to avoid the trip. Thanks!
BikeAnon
by BikeAnon
Put the bolt back in.
Tighten it to hand-tight.
Back it off three turns.
Insert a straight hex key (or T handle"
Hit key with hammer lightly.
BikeAnon
by BikeAnon
WAIT... I may be thinking of a different type of clamp.
I was thinking of this type:
Post a pic of yours.
wingguy
by wingguy
Yeah, they tend to take a set and you have to muscle them loose. Undo the bolt. Grab the saddle. Twist it left and right until you hear a crack* and feel the clamp free up. Move seatpost.
* Not joking :wink:
BikeAnon
by BikeAnon
Is it this clamp? The lower bolt shown on right?
From http://cyclingtips.com/2015/06/first-look-the-2016-tcr-advanced-sl/
BikeAnon
by BikeAnon
wingguy wrote:Yeah, they tend to take a set and you have to muscle them loose....
A proper cyclist does not have the upper body strength required to maintain bicycles. :lol:
wingguy
by wingguy
BikeAnon wrote:Is it this clamp? The lower bolt shown on right?
Nah, I'm pretty sure he's talking about the recessed wedge you showed before. He said Advanced, not Advanced SL. Plus there's no way the mast topper is getting stuck, while the wedges do it all the time.
tacostand
by tacostand
BikeAnon wrote:WAIT... I may be thinking of a different type of clamp.
Yes - it looks like that. I don't have the integrated seat post. I'll take a pic of mine in the morning and post. Thanks for the help!
Canofale
by Canofale
Had the same issue with mine, I rocked the post back and forwards slightly whilst pulling with quite a bit of force until it suddenly gave. The previous post regards undoing slightly and giving a gentle tap makes sense, I'll try that next time.
2015 Caad10 Ultegra 7.1kg
2016 Giant TCR Advanced Pro 6.6kg
tacostand
by tacostand
Sorry - having problems posting the pic. I've tried to attach a jpg.
dlcrep
by dlcrep
Loosen the bolt to where it's barely threaded on and lightly tap the nose of the saddle back. Sometimes you might have to hit it at an upward angle.
Bike112
by Bike112
Were you able to resolve the issue with the post. I'm having the same issue with mine. If so...what did you end up doing?
Also....can I ask a question about the wedge and post interface.
So...when the bike shop adjusted seat post and tighten the wedge bolt...the mechanic tightened the bolt until he heard a couple of clicking noises. Is that normal? Did you hear the same?
The reason I ask....is that I have been hearing some creaking from either saddle or post. I can't figure out which one. So I want to remove seat post to inspect for cracks but I am having trouble removing the seat post.
Thanks,
Joel
wingguy
by wingguy
Those 'clicking noises' should have come from the torque wrench he was using to tighten the wedge, not from the wedge itself.
And again, twist the saddle side to side a bit, the wedge will let go.
Bike112
by Bike112
@wingguy
Unfortunately....that is not the case...he was using a regular allen key not a torque wrench.
wingguy
by wingguy
In that case, things may not be good. :shock:
