Specialized Tarmac Di2 What to replace?
sythe
by sythe
Hi,
I'm a proud owner of a Specialized Tarmac Elite which I've upgraded with an Ultegra Di2 groupset.
Last week I was in the bike shop and weighted my bike, and it was 8.6 kilo (8600 gram). Not that bad, but I think it's possible to get a kilo off.
I listed all parts in an excel sheet and came to a lower number, so I think I've forgot something.
Here is the Excel sheet of my listings:
https://www.dropbox.com/s/5sfybmjv19jmy0g/Frame%20gewicht.xlsx
My question is what you guys would recommend to replace? And for which alternative.
KCookie
by KCookie
Nice build, but would look even better if the decals were removed from the wheels. Changing the pedals to say Time and one of Berks padded saddles could save you around 180g. Just depends on budget. !!
Wheels. I guess yours are really heavy.
Otherwise saddle, seatpost, brakes, pedals.
sythe
by sythe
They're 1800 grams. But I like the stiffness and the alloy breaking area (no need to change breakpads and breaks good in the rain).
Any suggestions for deep wheels within this budget (~900 EUR)?
Swannie
by Swannie
the weight of the seatpost can not be correct!
My S works seatpost weighs more!
Swannie
by Swannie
this is mine, @ 7.830 kg
same frame, wcs stem and handlebar (alu), s works seatpost, toupe saddle, Tune wheels @ 1430 grams.
alpinestar
by alpinestar
The bike looks nice! :) But 420 grams for handlebars! loks to be saved there at a relative cheap price!
Timmy269
by Timmy269
Maybe this way you can see what you can change on your bike
My Sworks tarmac weights 7,4 kg.
Sworks Frameset
Ultegra DI2
Rotor 3d+ mas spider
Rotor Qrings 53/39
Chaincatcher specialized
Dt Swiss rc spliine 55 (1575gr)
Sworks Turbo 24mm (210gr x 2)
Tube: continental
Sworks Power saddle (161gr)
Sworks aerofly handlebar (250gr)
Sworks SL stem (100gr)
Swrap HD tape
D-fly
K-edge xl garmin mount (33gr)
Look Keo Blade 2 (110gr)
Elite Custom race bottlecage (Yesterday changed by Sworks Rib cage II carbon 20gr each)
sythe
by sythe
Thanks Timmy,
Can you add the weight for each part in your post? That way I can figure it out a lot easier!
wop
by wop
Why do you want to make you bike any lighter? To climb mountains right?
Those 60mm wheels are useless in the mountains. Get a set of fulcrum zero's and you lose 0,5kg.
When riding on a flat area u can still use the FFWD's, weight doesn't matter that much if there are no hills.
junchen
by junchen
If OP has Ffwd 60mm in tubs, it should be 1.35kg.. Can't see clearly due to the low pic resolution
Sent from my SM-G920I using Tapatalk
chris14
by chris14
Great looking bike!
I agree with Alpinestar, the handlebars are a good start, I am surprised of the stem too, you could put a Uno stem on it or lyti. I would keep the saddle though, I find the toupe really comfortable and not too heavy
CEVelo
by CEVelo
If you want to make it lighter:
1) Wheelset. It's easy to get something around 1,350-1,400 grams these days, or even lower.
2) Stem (anything more than 120-130grams seem heavy)
3) Handlebar (should easily find one around 200g-250g, 400g is rather porky)
4) Crankset (consider a DA)
5) Brakes (get DA or EE breaks)
6) Pedals, drop the 105s for DA.
And so on. Before you know it, you have a 6.8kg bike.
mpulsiv
by mpulsiv
Timmy269 wrote:Maybe this way you can see what you can change on your bike
Sworks Frameset
Ultegra DI2
Rotor Qrings 53/39
Tube: continental
Swrap HD tape
D-fly
S-Works stem 100 grams? Last I checked, Specialized stems are over 140 grams.
Nejmann
by Nejmann
Sworks Frameset
Ultegra DI2
Rotor Qrings 53/39
Tube: continental
Swrap HD tape
D-fly
[img]picture[/img]
Like 80% of the people who rides a tarmac, they don't fit on it. So that 80/90 stem could easily weigh 140 grams? :mrgreen:
