Specialized Tarmac Di2 What to replace?
Nejmann wrote:mpulsiv wrote:Timmy269 wrote:Maybe this way you can see what you can change on your bike
My Sworks tarmac weights 7,4 kg.
Sworks Frameset
Ultegra DI2
Rotor 3d+ mas spider
Rotor Qrings 53/39
Chaincatcher specialized
Dt Swiss rc spliine 55 (1575gr)
Sworks Turbo 24mm (210gr x 2)
Tube: continental
Sworks Power saddle (161gr)
Sworks aerofly handlebar (250gr)
Sworks SL stem (100gr)
Swrap HD tape
D-fly
K-edge xl garmin mount (33gr)
Look Keo Blade 2 (110gr)
Elite Custom race bottlecage (Yesterday changed by Sworks Rib cage II carbon 20gr each)
[img]picture[/img]
S-Works stem 100 grams? Last I checked, Specialized stems are over 140 grams.
Like 80% of the people who rides a tarmac, they don't fit on it. So that 80/90 stem could easily weigh 140 grams?
The 110mm weights 110-115gr, mine is shorter so....
http://www.specializedconceptstore.co.u ... tsmtbstems
- cyclespeed
6.0kg exactly, 52 frame size.
Not too difficult really using a decent set of tubs, Di2 9070 and an AX saddle!
I've since swapped the Syntace bars (excellent) for 3T Aeronova LTD's (excellenter!) thereby saving 10g!
2013 S-WORKS frame set : 1400g
shimano 6800 groupset : 2324g
dura-ace 9000 c24 + 4000s + tube : + qr + rim tape : 2185g
deda zero 100 drop bar(44) : 255g
deda zero 100 stem(90) : 125g
S-WORKS seat post : 200g
2012 S-WORKS toupe : 120g
5800 pedal : 285g
lizard skin 2.5mm : 60g
cable set : 250
5800 pedal : 285g
cable set : 250
