Geometry choice - please help!
KH
by KH
For logistical and financial reasons I need to make a decision on a new bike today. I am clueless about geometry so any help would be very gratefully received.
The bike I have just broken (56cm) was a perfect fit. The key geometry stats for that bike were:
Effective top tube: 560mm
Seat tube: 540mm
Headtube: 155mm
Stack: 560mm
Reach: 394mm
All angles etc are pretty much the same as for the new bike I am looking at. The issue is that my old 56cm bike would sit somewhere in between the 54cm and 56cm sizes for the new bike I am looking at. I realise that bike fitting over the internet is dubious at best but I'm really struggling to make a decision today and I won't have a chance to test ride. For the new bike these are the geometry stats:
54cm:
Effective top tube: 549mm
Seat tube: 540mm
Headtube: 135mm
Stack: 537mm
Reach: 390mm
56cm:
Effective top tube: 565mm
Seat tube: 560mm
Headtube: 160mm
Stack: 565mm
Reach: 398mm
Is it possible from just those key stats to determine with a reasonable degree of accuracy whether the 54cm will be too small or the 56cm too big? Which do you think is the closest match to my old bike.
Thanks for reading and I await the wisdom of the resident geometry gurus on here!
CPongpanich
by CPongpanich
That's tricky. I'm by no mean a guru in geometry but I'll suggest you to go for the smaller one - the 54. As with small frames, you have more flexibility afterward, eg. extend the stem length. But with larger frames, you tend to be stuck with it.
wheelsONfire
by wheelsONfire
The 56 sized is only 5mm higher than your previous bike (stack).
The bar will be 4mm further forward (reach).
You could change headset top cap for a lower (see link below) and either you handle the 4mm longer reach, or you change to a handlebar with shorter reach.
Here is the lower headset covers
http://www.certifiedslammed.com/#_=_
Bikes:
Open *UP* (2016.04.14)
Tenlegs
by Tenlegs
Include in your Key geometry stats details like stem length and angle, how many spacers if any?
seat tube angle
Mr.Gib
by Mr.Gib
if your broken bike was indeed a perfect fit, the new 56 can also be a perfect fit with some very minor tweeks. The 54 not so much.
fignonsbarber
by fignonsbarber
Also need to consider what your saddle height is, and how many spacers you had on the broken bike. The only reason to not go with the 56 is if your old bike had a very low saddle height and/or lots of spacers (the 54 has a 2cm shorter HT than your bike).
KH
by KH
Thanks very much for all your input; really appreciate it and you have helped to clarify my thoughts.
I have gone for the 56cm. I had a fair amount of seat post showing on my old bike and I also had a 120mm stem.
I will be sure to post the eventual build in a week or two on here once I have swapped out some parts!
tinozee
by tinozee
the 56
edit - oops just saw you decided. Enjoy new frame.
KH
by KH
Thanks! Always good to get a little extra reassurance!
