Largest cassette for SRAM Wi-FLi
Yes. Your frame and derailleur hanger will play a part in it.
I've done this on a Specialized Roubaix and a Fuji 'cross bike.
Switching to a mid-cage Shimano setup on each of them made a 36 no longer fit.
- Contact:
boots2000 wrote:Can an 11 speed SRAM Force Wi-Fli rear derailleur handle an 11-36 cassette?
Force Wifli will max out at 32 teeth according to Sram. If your frame and hanger hang down a little extra you will be able to squeeze an extra tooth or two. The issue is the upper pulley hitting the cassette.
