Trusworthy tubes for your clincher race wheels ?
LouisN
by LouisN
HI all,
I'm building some clincher wheels as spares for races, or "bad weather" race wheels.
Will probably put some new Vittoria Rubino Pro Speed G+ tires on them.
I was wondering what tubes do you guys use that are relatively light, but trusworhty ?
I've tried latex tubes, but without much consistent success. I didn't try all brands though, Michelin was the most trusworthy, not for long though...
Louis :)
wheelzqc
by wheelzqc
Bonjour Louis,
Have you tried Michelin A1 AirComp Ultralight Road Bike Tube ? They are light(70g) and I haven't had much punctures with them, even commuting.
Marin
by Marin
Panaracer R'Air or Conti Supersonic.
I even used a Supersonic in a 38mm tubeless CX tire once after I burped it right before a race. Survived the race no problem even tough it's only rated to 23 or 25mm.
nemeseri
by nemeseri
I use conti race light tubes (75g) for general road riding and conti race tubes (100g) for commuting. I found the superlights somewhat fragile and prone to pinching, but it might be only me.
Lugan
by Lugan
A little heavier, but to err on the side of durability, I use Maxxis Welterweight tubes. Better yet, go tubeless if you can.
BikeAnon
by BikeAnon
Do any of you really detect the slightest difference in tubes?
My "favorite" tubes are Vitoria something-or-other, because they are lighter. But I truly can't tell the difference between them and Nashbar/Kenda cheapos. Not in ride/puncture resistance.... nothing.
Since you goal is "spares" or "bad weather", you're either already dealing with a failure of your "good stuff" or you're wanting wanting great puncture resistance that is desireable when it's wet.
In either case, tire choice matters, tubes... not so much?
bombertodd
by bombertodd
I've had great success with Michelin A1 and Schwalbe tubes.
Delorre
by Delorre
Michelin Ultralight (147gr the set) for over 2 years. Not a single issue until today! Back in years Specialized Turbo. Below 60 gr and reliable. Don't know if they are still available.
pavel
by pavel
Michelin A1
F45
by F45
Vredstein latex.
stormur
by stormur
I never had puncture with 1 type of tubes only... Kenda. Not in road, not in CX. Plus is they're lightest "standard" (not hyper-lite) butyl tubes I owned...
Mark Twain
