LW GEN III Freehub light play
nismosr
by nismosr
I noticed there's a small light play on the cassette freehub on my LW gen iii, how do I get rid of it ?
http://vidmg.photobucket.com/albums/v44 ... yukk1v.mp4
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
maverick_1
by maverick_1
Is there any play after installing the cassette/mounted on the bike with skewers tightened?
Have you tried changing to a different freehub? Any difference?
kavitator
by kavitator
has LW Dt swiss freehub?
put wheel in frame and tighten skewers
keith
by keith
It's a standard DT Swiss freehub, so maybe ask their tec. support?
I service mine twice a year. You just pull off the outer casing to expose and clean the mechanism inside, no nuts or bolts to undo. A bit tricky to do with the bare hub so I do it with the cassette still on, wife holding the wheel and me pulling on the cassette, fingers behind the largest sprocket, it lets quit suddenly!! Plenty of YouTube videos demonstrating how to do it. Special grease is supposed to be needed to service it. Quite expensive if you can find it! Without the service I eventually get a horrible creaking when pushing low gears up big hills...
Riding my road bikes around Eryri
http://www.strava.com/athletes/keith_robertson" onclick="window.open(this.href);return false;
TwiggyTN
by TwiggyTN
Has the thin washer been lost in the freehub assembly?
Sent from my SM-N920V using Tapatalk
WeightySteve
by WeightySteve
Like this?
http://s1154.photobucket.com/user/dudos ... 8.mp4.html
If so, and you want a bit of "dirt", you can read my full tale with Carbonsports about it here:
viewtopic.php?f=3&t=104926
If you aren't bothered about the details, basically replace the DT Swiss 190 bearings for a DT Swiss 240, and that should sort it. Mines been ok for 10K miles since I did that.
And yep, about twice a year I grease the insides up now, mainly when the noisy ratchet starts getting on my nerves. I don't free wheel much/at all, but man it gets loud when its really dry in there.
nismosr
by nismosr
WeightySteve wrote:Like this?
oh wow .. my freehub does not have the side to side play .. did you have that fix ..
nismosr
by nismosr
TwiggyTN wrote:Has the thin washer been lost in the freehub assembly?
im not familiar with the thin washer .. and the freehub don't have one ..
nismosr
by nismosr
maverick_1 wrote:Is there any play after installing the cassette/mounted on the bike with skewers tightened?
with the cassette on yes still have the same play, but never tried it mounted on the frame, i just noticed it when I removed the rear wheel and removed the cassette. I will try it again mounted this time see if it moves . thankyou
