Hello all,
for the last 10 years I have been using full 7800 dura-ace group, and although I'm extremely happy with its function and durability, I don't like the shift cables in front of my bar and am thinking about an upgrade to 11speed and perhaps electronic too. Since I already have a (105) stages, and also would like to keep the costs down regarding this upgrade I was thinking - depending on the group that I choose - to keep the crankset and chainrings from the 7800 for the time being. Do you think this is compatible? My current options are:
(i) current D-A mechanic. pros: up-to-date, probably the most durable/easier to find parts in the long term, weight-saving, can use my stages with the new crankset if needed.
(ii) Ultegra Di2. pros: electronic, cheaper parts, more "workhorse" group, can use my stages with the new crankset if needed cons: probably slight increase in weight, not fully rational but moving from D-A to ultegra feels somewhat less of an upgrade
(iii) Chorus mechanical. pros: most elegant imo, i always would like a campa-groupset, weight-saving but only slight, cons: would need a new freehub-body, would have to stick to my current crankset (if possible) for now, and the mix is not that "elegant"
(iv) e-Tap upgrade set. pros: In my opinion the coolest/most advanced groupset right now, only brake cables, weight-saving but only slight cons: would have to stick to my current crankset (if possible) for now, perhaps also keep the brake-bodies (if possible?)
What do you think? What would you do?
Thanks, lightweenie
7800 chainrings with 11speed setup?
I went to 11 speed from 7800 and kept my cranks. No issues whatsoever. I went Shimano mix with DA shifters and front derailleur, Ultegra rear. Couldn't be happier.
Sent from my SM-G900W8 using Tapatalk
Oh...the 7800 brakes suck with 9000 levers. I just upgraded to EEs. Now braking rocks again.
10 speed crank sets work just fine with 11 speed chains.
