Thoughts on S-works Crankset
DavidMLee
by DavidMLee
Currently using DA 9000 crankset, and will probably buy S-works crankset because some of my bikes use BB30.
Although S-works has a cool factor - carbon fiber in it,
I cannot justify the price only depending on carbon parts and diminutive weight advantage.
Anyone who can explain something good about it other than carbon parts and weight?
Legend HT 9.5 RED 22
Colnago C60 Super Record
S-Works Tarmac 2016 eTap
S-Works Tarmac 2015 DA
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Spesh Venge Elite 105
nathanong87
Resident master of GIF
by nathanong87
it looks tighter. #aestheticsiseverything
DavidMLee
by DavidMLee
Cannot disagree.
Gotta find some kinda practical reason to buy one.
Maybe I just wanna justify credit card bill.
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Rick
by Rick
I can't think of any logical advantages.
But if you want it for whatever cool factor you perceive in it, just buy one. You don't need to justify to anyone else. :thumbup:
itsacarr
by itsacarr
Stiffness and Weight really are the defining characteristics of the crank itself. Looks are personal preference obviously. But functionally I found it to be extremely stiff and lighter than most the cranks I have owned. I have both the 9000 and the current generation S-Works SRM and the S-Works (although I'm selling it for other reasons) is probably my personal favorite.
If you have BB30 bikes and don't want to mess about with adapters and this being weight weenies ... it's certainly not a bad choice at all. Mine are paired with Praxis rings as you might imagine.
Just ride ..
madcow
by madcow
It scored very well in our crank testing: http://blog.fairwheelbikes.com/reviews- ... k-testing/
DavidMLee
by DavidMLee
Thanks for the well documented test.
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Slack
by Slack
Reason: Deleted, please no unsolicited advertising. Thanks.
DeLuz
by DeLuz
I had one on my Tarmac but sold that bike. It looked great and was very light and stiff.
No complaints.
Now I have a PF30 Cannondale and went with Campy Over-Torque because it fits and was on sale cheap and I have a Chorus groupset.
I like the look better than Specialized but depends what your groupset is. The only thing i don't like is it sticks out a ways from the BB as it was designed for multiple types of BBs and has press fit arm instead of Hirth joint. But it still has low Q-Factor and works fine.
newforker
by newforker
Weight? My S Works crank in 172.5 with carbon 130 spider and 53/39 Praxis Rings weighed in at 537 grams?
That set up in a DA crank would be ballpark around 640-80? Plus if the frame is BB30 then add the weight of adapters/reducers.
Also relatively stiff as per the FW test.
nathanong87
by nathanong87
and it looks so sick
cdtf
by cdtf
madcow wrote:It scored very well in our crank testing: http://blog.fairwheelbikes.com/reviews- ... k-testing/
Your old website was soooo much better...
Why did you change it? QQ
Valbrona
by Valbrona
So much better to run a BB30 crankset in a BB30/PF30 shell than a regular crank.
But there is a lot of choice out there ...
CBJ
by CBJ
I have run the for a long time with no problem at all really nice crank. If my current bike did come with the Praxis bb I would have ran them again but gave them to my wife.
Qman
by Qman
The S-works also allows you to install whatever rings you want, depending on your requirements for weight, aesthetics, and shifting. You can go for full carbon rings, or chunky stiff aluminum, or wispy Extralite.
My crank is 535 grams including BB. You could go even lighter with ceramic bearings. So, it's possible to save quite lot of weight.
Also, you can pick up a used set for relatively little money.
