Tubular or Clincher
pdlpsher1 wrote:For those of you who run tubeless do you add sealant to the tire? If yes how much additional weight increase do you see and does the sealant detract from the benefits of having tubeless tires?
Yes, I use Orange Seal. I run it in my tubulars as well. There are no downsides, IMHO. It saved me in a race once and I have had a few punctures on the road that sealed without stopping as well. As for weight, I don't know but too small for it to be an issue for me.
Straight line speed is a wash these days ... tho note the top clincher CRRs are with latex tubes which is less safe (esp with CCs) than tubs
Cornering and descending - way more confidence inspiring and safer with tubs
Tubular for racing and Clincher for training rides.
Although I heard recently clinchers' rolling resistance and performance have proven to be superior to tubulars' despite weight penalty.
Legend HT 9.5 RED 22
Colnago C60 Super Record
S-Works Tarmac 2016 eTap
S-Works Tarmac 2015 DA
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Spesh Venge Elite 105
Cervelo R3 2015 UT
Cervelo S2 2014 UT
sethjs wrote:Bicyclerollingresistence.com has started testing tubulars. First test was conti competition. About 2 watts worse than the gp4000s2
Don't forget that it comes with a butyl tube (they tested the gp4000 with latex) and the measured with is 25mm, while the gp4000 25c has a 27mm measured width on the test rim. So the real difference is less than 2W. You should compare the results of a 23c clincher gp4k with a thin a butyl tube.
Also continental glue is worse than mastik one based a recent study I read, and it's well know that the glue job is critical in tests like this. I can't wait for the next tubular test, I'm sure that in this particular test they will be slower, but I think the difference is very small.
Tom A over on Slow Twitch has tested a few Tubs .....
http://bikeblather.blogspot.com/...peed-course-and.html
https://docs.google.com/.../edit#gid=1224624714
C64 My Sixty 4 SR EPS 12
Only tubular- clinchers suck
