Are 2015 Campag Chorus shifters compatible with Athena RDs?
phlip
by phlip
Because I do not like the aesthetics of the new Chorus rear derailleur and assume that the 2015 Chorus front derailleur shifts easier due to the larger arm, I would like to combine 2015 Chorus shifters with an Athena rear and 2015 Chorus front derailleur. Is that possible? Or do the (rear) shifters have different shift-cable pull ratios?
lynton
by lynton
According to Campagnolo shifters in the Chorus, Record and SR range that are marked with a A are only compatible with derailleurs with the same marking due to changes in the models.
bikerjulio
by bikerjulio
We have it on a high authority here that there is a difference with the pull ratio 2015 Chorus and Record RD's.
I have not yet seen anyone actually demonstrate what that difference is.
Why don't you try it and be a pioneer?
There's sometimes a buggy.
One.
AJS914
by AJS914
phlip wrote:Because I do not like the aesthetics of the new Chorus rear derailleur and assume that the 2015 Chorus front derailleur shifts easier due to the larger arm, I would like to combine 2015 Chorus shifters with an Athena rear and 2015 Chorus front derailleur. Is that possible? Or do the (rear) shifters have different shift-cable pull ratios?
I think your options are:
Go all 2015 Chorus
Go all 2015 Athena
Or, get 2014 Chorus shifters with a 2014 Athena rear derailleur and 2014 front derailleur
joeyb1000
by joeyb1000
My understanding is that Athena derailleurs did not change. That would make them compatible with pre-2015 Chorus shifters.
DeLuz
by DeLuz
I looked into this before building my new bike last year and I think the answer is no.
What is wrong with the aesthetics? I have all Chorus and RD looks very nice.
stormur
by stormur
I tried. Record15 Shifters, Athena FD / RD . It doesn't work.
Personally I like aesthetics of '15 components more ( except crank ! )... But, if you like '14 try NEW '15 Athena shifters ( EPS style thumb knobs ) : if you can live without multiple upshifts.. it just works like a charm. Way better feel in comparison to '14 levers ( parallel thumb knob ).
Mark Twain
phlip
by phlip
Thank you, Stormur. You have answered my specific question.
Have you tried the 2015 Chorus, Record, or Super Record front derailleur? If so, is it significantly better than the respective 2014 front derailleur due to its larger arm? I have to gauge whether the new front derailleur would be worth the ugly rear derailleur. I agree with you about the crank. I dislike the rear derailleur just as much. ;-)
If I go full Athena, I will definitely use the new Athena shifters with the new style thumb lever.
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
I know I am biased, doing for a living what I do ... but I think the 2015 mechanical shifting overall is very sharp, nearly as good as electronic.
For competition use, it seems to me like a worthwhile incriment against the 2014 and before 11s.
Provided that the four arm chainset is used, the new CH, RE or SR FD will make a noticeable difference to the front shift when paired with the matching levers - however, it's not just about the FD, the extra rigidity of the outer chainring offered by the four arm chainset plus the revised ramping and pinning on the chainrings all together are what make the difference.
If you want "better" but not "best" shifting, then go for a full 2015 Athena group, as the crankset runs the SC13 chainrings that form the basis, in terms of tooth profiles, ramps and pins of the four-arm chairings, but they lack the very high chainrng rigidity conferred by the four-arm crankset.
phlip
by phlip
Thank you very much for this very good description, Graeme.
