SRAM Red eTap With 11 X 32 Cassette
Can we get that same pic while on big ring up front and the 32 cog please? And also on small/small. And are those standard rings (39/53) up front, or something else? Thanks.
Calnago wrote:Can we get that same pic while on big ring up front and the 32 cog please? And also on small/small. And are those standard rings (39/53) up front, or something else? Thanks.
Me?
http://www.ceramicspeed.com/sport/news/ ... -for-sram/
" the OSPW System is delivered in two product versions to fit mechanical groupsets or eTap. The compatible SRAM models are thus the 10-speed and 11-speed SRAM Red, Force and Rival and can accommodate cassettes of up to 32t."
2015 Trek Emonda SLR Project One - Red eTap - Zipp 303 - 6.48kg
2016 Cannondale SuperX Rival CX1 - 9.29kg
iRide4Sue.org Please Donate to fight Cancer. $27,000 raised in 2017
sugarkane wrote:i built the worlds first EPS super record medium cage mech the other day...
perfectly working 11/32 setup
So help a mechanical imbecile with this... You just took the cage from a Potenza derailleur and swapped it onto the EPS derailleur? And it works perfectly!?!
Sent from my Nexus 6 using Tapatalk
tikka wrote:So help a mechanical imbecile with this... You just took the cage from a Potenza derailleur and swapped it onto the EPS derailleur? And it works perfectly!?!
Yes the cage from the Potenza is compatible with all 11 speeds derailleurs. They have the same mounting system.
- tomyboy123
Anyone tried new XG-1190 11-30 cassette with E-tap rear derailleur?
When I screw B tension bolt all the way, I have 10mm between 28th sprocket(11-28 cassette) and the upper jockey wheel.
So in theory 4-5 mm of spare room to accommodate 30 sprocket?
Dura Ace 9000 SS, even though it supports only 28, works just fine with 32. Does Sram also have some reserve for 11-30 cassette, regarding the statement that it is NOT compatible?
tomyboy123 wrote:Anyone tried new XG-1190 11-30 cassette with E-tap rear derailleur?
yes, works with no problem
etap (53/39) with XG-1190 11-30
- tomyboy123
Thanks.
I was considering new 9100 11-30, but than I look at my old 11-28, what was that strange noise on the 3 sprocket and there it was, one broken pin. So I am not buying DA any more.
Will try Sram RED, there are two versions
SRAM XG-1190 2016
https://www.bike24.com/p2174914.html
and
SRAM X-Glide 1190
https://www.bike24.com/p256950.html
It says, SRAM revised graphics to match SRAM RED eTap components. So other that that same cassette?
Only hope that will work OK, because the DA cassette, despite construction problems, works really great with Sram in every gear, even better than with DA Di2 system, that I had before..
SRAM XG-1190 2016
and
SRAM X-Glide 1190
ferrarista wrote:tikka wrote:So help a mechanical imbecile with this... You just took the cage from a Potenza derailleur and swapped it onto the EPS derailleur? And it works perfectly!?!
Would this work with Pre-2015 Chorus RD's?
morrisond wrote:ferrarista wrote:tikka wrote:So help a mechanical imbecile with this... You just took the cage from a Potenza derailleur and swapped it onto the EPS derailleur? And it works perfectly!?!
For Pre-2015 campy 11, I used the long cage from an Athena Triple and put it on Chorus for the ladies bike to fit 11-32.
Yes it works on all 11 speed derailleur.
kkibbler wrote:glam2deaf wrote:Don't really want to find out how the 53 works on the road. Was mostly an experiment before I put the 32 on my CX bike.
As for after market cages, it looks to be just Shimano for now who get the nice upgrades. Would a force wifli cage fit to an etap RD?
IIRC the pulley cage on SRAM RDs are not user-replaceable. It's pinned to the p-knuckle.
I beg to differ...
