Colnago C60 - seatpost loose fit?
When I tighten the collar, the gap on the collar itself closes but the slot on the frame only closes slightly, perhaps the collar is too big. I was in contact with the uk distributors this morning. They've asked me to return the seat post and the collar and they'll replace both and see what difference that makes. They think it's more likely that the seat post or collar are outside tolerance rather than the frame. I'll update when I receive the new seat post and collar.
By the way, the C60 I was experimenting on with this issue also had that same white seatpost. It took some effort to get it into the frame and even without the seat collar on the bike it was snug enough that I could pick up the frame without fear that the frame was going to slip off. It was beautifully finished both inside and out snd even though snug the finish was so smooth that no scratching was happening at any point despite its snugness. In your case where you say you can tighten the collar all the way to close the gap something just seems wrong there. That gap is pretty big.
I can guarantee that the 2016 frameset (as pictured) has an extreme loose fitting post and unclamped it will drop down (and schratch the white paint so nothing with smooth....). And for the info. at 3 nm ther was still some play.....
Hey @Sharkman, what's up with the wheels in that pic above... Bora wheels with FF decals photoshopped on them?
Nope, Bora's will be ordered, these are just some cheap china knockoffs with ffwd decalls under the (yellowing) clearcoat.
Funny, I was just going to add that, about the seat post collar being too big. Re the seatpost, didn't you say you actually tried a different seatpost from your mtn bike and still had the same slop, so much that there was some wobble present from the play? And that the genuine seatpost you had was not supplied with the frame? Does the seatpost collar have the Colnago logo on it, because I can't think of any of their frames that use a larger one, but I'm not familiar with the lower end models. Would like to hear the resolution on this.
sharkman wrote:Hey @Sharkman, what's up with the wheels in that pic above... Bora wheels with FF decals photoshopped on them?
Hmmm... So someone goes to the trouble of producing cheap China Bora knockoffs and puts Fast Forward stickers on them? Don't quite get that one.
Update!
Received a replacement seatpost and seatpost collar today. I suspect the problem was with the collar because the new one tightens perfectly now at about 3-4Nm and still a gap of 2-3mm between the edges of the collar. Seatpost firm, no movement at all.
Excellent! And is the seatpost a snugger fit than before as well. Regardless of that however, what you describe now is what I would consider pretty normal.
Sliding in with no resistance is fine. I have a matte finish one that is pretty easy that way. The tighter ones are like some of the new ones with thick white paint and thick white gloss. That's enough to make the fit more than "snug" from the get go.
