New dura-ace R9100
bungis wrote:Accurate cadence is critical to accurate power data and I don't think accelerometers are up to the task at least from my experience with them.
Agreed. At an angle to the topic, but the cadence sensor in Power2Max meters is lame for this very reason.
Back on topic; anyone tried the new rim brakes down a steep descent yet, and if so, do you notice any difference to 9000?
TheDarkInstall wrote:Back on topic; anyone tried the new rim brakes down a steep descent yet, and if so, do you notice any difference to 9000?
I have the regular rim brake version (not direct mount) and honestly I can't tell the difference and I only had 6800 before.
What's the latest info on 9150 Di2 components releasing day? (FD, RD and ST)
One of my friends will have it on 16th Dec, but it's coming off a show bike so hardly 'available'.
when we someone post real weights on the scale for the mech group? anyone? in the past fairwheel bikes would be first
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
ex 2019 S-works SL6
R9150/R9160 dealers manual posted on 02.12.2016:
http://si.shimano.com/pdf/dm/DM-R9150-00-ENG.pdf
it have info about synchronized (and semi-synchronized) shifting
it have info about new internal junction EW-RS910 ,
no info about new external junction EW-RS911
(suggested external junction: old model SM-EW90)
SW-R9150 semi-sprinters semi-climbing shifter user manual:
http://si.shimano.com/pdf/um/UM-71G0A-000-00-ENG.pdf
EW-WU111 wireless unit user manual:
http://si.shimano.com/pdf/um/UM-2710A-002-00-ENG.pdf
ST-R9150 sti user manual:
http://si.shimano.com/pdf/um/UM-6VE0B-003-00-ENG.pdf
SM-EW90 junction user manual updated 30.11.2016:
http://si.shimano.com/pdf/um/UM-7FE0A-005-00-ENG.pdf
no information about synchro shift mode
EW-RS911 junction - not released, no pics, no pdfs
(I guess it is like SM-EW90 with synchroshift mode switch)
EW-RS910 junction user manual posted 02.12.2016:
http://si.shimano.com/pdf/um/UM-71J0A-001-00-ENG.pdf
includes information about synchro shift mode:
Good info you found there. The wiring of the bar end junction box is interesting with it coming in from a hole near the end of the bar. I tried to see if I can run a wire through my aerofly and there is something blocking it near where the shifters mount. I would assume that's for reinforcement in that area.
sun wrote:Good info you found there. The wiring of the bar end junction box is interesting with it coming in from a hole near the end of the bar. I tried to see if I can run a wire through my aerofly and there is something blocking it near where the shifters mount. I would assume that's for reinforcement in that area.
I found the same thing on my Easton EC70 aero bars. something blocking the path around the clamping point
My 2016 Evo Hi-Mod
viewtopic.php?f=10&t=141400
