Shimano Ultegra 6800 Chainset compatible with full 7900?
I was wondering if I purchase a Shimano Ultegra 6800 Chainset (52x36) would it be compatible with my existing 10speed 7900 setup? I have a Shimano Dura Ace 9000 BB92-41B Press Fit Bottom Bracket fitted to my bike at the moment.
- Frankie - B
- Admin - In the industry
Is the diameter of the axle the same? (yes, both 24mm) Is the length of the axle the same? (probably yes, I'm not a shimano tech geek) then it will probably work.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
Yes, 11 spd and 10 spd shimano cranksets are interchangeable. Though shimano for obvious reasons don't say so.
Sent from my SM-G920I using Tapatalk
