Trek Madone 9 Series Power Meter Options
jekyll man
by jekyll man
1 of the problems trying to fit a Rotor 3D24 Power2max (and probably other versions too) into frames with larger shells is the actual internal diameter of the powermeter unit itself.
Classic's have a limit of ~53mm, S-types limit is 57mm.
So while in theory because they have a 24mm axle, they should fit, in reality they might not due to how built up the shell area is.
I've not actually looked at the trek to comment on its girth.
Not sure if there are a few people out there running 30mm axle conversions in BB90 but suspect the bearings are going to be fragile due to their size.
Official cafe stop tester
Calnago
In Memoriam
by Calnago
Pretty sure you can't physically get a 30mm through a BB90 shell, what you're I believe referring to is people running a 30mm crank in a BSA type shell where the hole is big enough but not big enough to use standard size bearings with it.
I do get what your're saying about the "girth" of the shell possibly being an issue however.
stang1
by stang1
Calnago wrote:Pretty sure you can't physically get a 30mm through a BB90 shell, what you're I believe referring to is people running a 30mm crank in a BSA type shell where the hole is big enough but not big enough to use standard size bearings with it.
Yes, the Rotor UBB30 system. The bearings do look fragile but I myself am not going to risk it :noidea:
