Bar/stem combo for 1.25" steerer?
kkibbler
by kkibbler
I'd really like to get a set. So far I have only found 3 (of which only 2 are actually for sale):
Canyon H11/H36 Aerocockpit (I asked, they're not selling it (for now), not even to existing Canyon customers)
Giant Contact SLR Aero
Scott/Syncros RR1.0, same as on the new Scott Foil, which interestingly has a 1.25" steerer tube
Ritchey makes 2 models but neither specify steerer clamp size so I assume they're for 1.125".
Are there any other options, short of full-custom? I'd love to get the Canyon combo but who knows how long I'll have to wait for that to happen, if ever. The other 2 are probably fine, but aesthetically they're not that great.
junchen
by junchen
Been waiting for something like this.. Camping here...
Sent from my SM-G920I using Tapatalk
romalor
by romalor
you can find the canyon one on ebay or trocvélo
A2ON
by A2ON
Hey any updates on this. Just stuck the Zipp sl70 aero bars on my giant propel. Love the bars but they need the wider sprint stem from Zipp to look "really nice" but Zipp don't sell it in overdrive 2 fitment, giant do one a new SLR and an older SLR the older seeming bigger and more square .
So what stem options are out there or just sell the Zipps and get something else.
RyanH
by RyanH
I have the Syncros bars, they're very stiff and the Kamm foil design makes them comfortable to ride on the tops. I also like the step for the bar tape to create a seamless transition. Weight was 387g iirc.
I think the measurements are off though since I ended up with a lot more reach than expected based off the geo.
Sent from my SM-G930V using Tapatalk
A2ON
by A2ON
Cheers.
I alsready have the Zipp bars. They are very wide so the small giant stem looks silly that's why the larger sprint stem looks so good but they don't do it to suit overdrive size.
This gives you an idea of the width
http://zipp.com/_media/images/dynamicpr ... 203qtr.jpg
Zipp do this one but again it's small http://zipp.com/stems/service-course-sl-os-stem/
Giant used to do this one it can still be purchased online eBay etc. Wider but very brick like to look at. 150g or so
http://climbonbikes.co.uk/store-images/product/slr3.jpg
This is the replacement, again same issue as Zipp it lacks the width to "match" the bars
https://www.giant-bicycles.com/en-gb/ge ... 584/62017/
Perhaps I should have just got these ?!
http://www.winstanleysbikes.co.uk/image ... 301271.jpg
SuperNonAero
by SuperNonAero
Bumping thia old thread, as I am trying the same thing with my bike (https://www.giant-bicycles.com/au/prope ... pro-0-2015)
We can now buy https://www.canyon.com/en-au/accessorie ... 4#id=62189
But I was wondering if there are more options for us now.
I would love to use that new madone setup.. best of both worlds.
cheers
Courie90
by Courie90
Has anyone mounted an canyon aero cockpit on annother brand bike ? I would like to do it on i giant, but don’t fins pics or info on the internet
Thx
calvin
by calvin
Courie90 wrote:
Tue Jan 08, 2019 9:46 am
Thx
yes, i have Canyon H11 cockpit on my Scott Foil
FXKalvis15 code at @montonsports
Courie90
by Courie90
Hey Calvin
Thx for the replay, as i can see on the picture you hust mounted the aero cockpit on the original bearing spacer from scott. so if i understand correct you don't need the special spacer from canyon, figure 101 in the link.
https://www.canyon.com/nl-be/accessorie ... =&id=64887
Im' not sure, if i would buy the giant, i need to swap the top spacer with bearing (the first one that is mountend on the steerer tube en contact with the frame) with the one from canyon (see link)
grtz
Angelo
calvin
by calvin
Yes i am using the original Scott spacers
SuperNonAero
by SuperNonAero
Has anyone tried using a convertor like so?
https://www.ebay.com.au/itm/1-1-4-to-1- ... 2657031770
Might be the best way to allow more options
dricked
by dricked
How is that suppose to work? You’d need to remove material from the steer tube, you’re going down in size not up.
IvanZg
by IvanZg
That should be reducing actual slot and allowing smaller diameter fork rather then doing anything to 1 1/4” steerer tube
dricked
by dricked
That makes sense.
