Cipollini Nk1k or Scott Foil 2016 HMX
jekyll man
by jekyll man
it's rare that a "whole" frame is made out of the same carbon throughout, so on first glance its easy to think one is "better" than the other, but unsurprisingly the manufacturers just pick the high points :wink:
How the fibers are actually glued together has a bigger bearing on the quality than a carbon "grade number".
Official cafe stop tester
REDUTOPIA
by REDUTOPIA
About the manufacturing and how the fiber are actually glued I think that NK1K is better since this is made 100% in Italy.
addict
by addict
ETT difference between FOIL and NK1K = 5мм, stock stem both 110mm at size M54. Think you don't need move to 90mm stem..
REDUTOPIA
by REDUTOPIA
addict wrote:ETT difference between FOIL and NK1K = 5мм, stock stem both 110mm at size M54. Think you don't need move to 90mm stem..
My size is S. Precisely those 5mm make the difference. Really, according to the biomechanical on the Mcipollini ideally I need a stem of 9.7mm so in the Foil 9.2mm.
This leaving the saddle in the correct position for me.
wheelsONfire
by wheelsONfire
You could also look for a handlebar with shorter reach!
Bikes:
Open *UP* (2016.04.14)
REDUTOPIA
by REDUTOPIA
wheelsONfire wrote:You could also look for a handlebar with shorter reach!
With the Scott Foil HMX is included the specific integrated handlebar.
wheelsONfire
by wheelsONfire
Yes that is right! Well, did you check the reach of that combo and not just stems length?
Same carbon, i wonder if any frame has one carbon only? I asked Gerard Vroomen what they use in UP.
He did not wish to expose what weaves, but told me he usually uses 4 different carbon weaves.
So i have seen most mentioning two. One only,.... i guess the Asian copy frames might do that!?
Bikes:
REDUTOPIA
by REDUTOPIA
wheelsONfire wrote:Yes that is right! Well, did you check the reach of that combo and not just stems length?
I think If the carbon fiber used is something to brag about, they would not hesitate to do this by declaring.
The reach of Specific integrated handlebar of Syncross is 80mm. The same considered from my biomeccanical.
The bad news is that for the size 42cm c/c they do only the size stem 10cm.
Furthermore, in the frame kit is included the handlebar but only in predetermined sizes and it is almost impossible ask this in a different size.
For example in the Kit frame size "S" is with a stem of 10cm.
So my choice is between Cipollini NK1K and Wilier Zero.6 but I prefer the Cipollini NK1K.
I think the choise is simple: if you are a lightweigh climber go for the Zero.6 otherwise Cipollini NK1K will be a better all rounder and certainly a much more exclusive frame.
REDUTOPIA
by REDUTOPIA
Exactly!! I am looking for a good all rounder.
I am 1.73m and 60kg.
AJS914
by AJS914
Just go order it. You know you want it. :-)
Calnago
In Memoriam
by Calnago
Ha! That should be a standard answer to a lot of questions on this forum.
Kayrehn
by Kayrehn
AJS914 wrote:Just go order it. You know you want it. :-)
My thoughts exactly. Don't know why OP bothered with the Scott option at all from start to end...
REDUTOPIA
by REDUTOPIA
So do you advice NK1K?
wheelsONfire
by wheelsONfire
You should order what you want! I think most is saying that it seems you want the Cipo?
(May i ask you, what price are you getting on that frameset (if you order just a frameset?)
I am curious, if you don't wish to expose it here, maybe you can send a PM?)
Or you just skip ordering a new bike and wait until 2017.
Bikes:
