105 Shifters+DA Derailleurs vs DA Shifters+105 Derailleurs
Best shifter/derailleur combo?
105 5800 Shifters + DA 9000 Derailleurs
9%
DA 9001 Shifters + 105 5800 Derailleurs
10
91%
Total votes: 11
zucchiniboy
by zucchiniboy
With my budget, I'm able to splurge just a little bit on my groupset. Essentially, I can do one of the following:
1. Shimano 105 5800 Shifters + Dura Ace 9000 Front and Rear Derailleurs
2. Dura Ace 9001 Shifters + 105 Front and Rear Derailleurs
Which one of these do you think would be the better move for the money?
Thanks.
mimason
by mimason
#3 Ultegra all around. Boom!
But if only 1 or 2 then #2 without question.
istigatrice
by istigatrice
Arts cyclery actually have a pretty useful post on this topic.
They recommend: Dura Ace shifters, 105 RD and Dura Ace FD.
I write the weightweenies blog, hope you like it :)
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
mpulsiv
by mpulsiv
Wait, Dura Ace has different cable pull ratio. Has this changed for 11 speed? Mixing 6700 and 7900 shifters and derailers was never optimal.
istigatrice
by istigatrice
Pretty sure all the 11 speed stuff is compatible, and I'm sure you could do the same with the 10 speed stuff too. Might have had issues with 6600 and 7900 but if it's the same series it should be compatible.
mattr
by mattr
Upgrade the shifters.
Always the shifters.
headwind816
by headwind816
7900 didn't mix with any other Shimano's 10-speed stuff. I got it to work with a 5700 RD but never typical Shimano smooth. The FD pull was different and did not have a trim feature.
On topic, I wonder about the difference in RD pulleys across 9000, 6800, and 5800. I'm rocking all 6800, but two winter seasons - and laziness on my part - has not been kind to my pulleys. It is my understanding that the 5800 RD doesn't have the same spec has 6800, which is still a bit beneath 9000. When I have to replace the entire RD, I will go with a 5800.
I would match FD with shifter although no citations to support this action; a cheaper RD would put more $$ in your pocket to spend towards wheels.
mpulsiv
by mpulsiv
This is all speculation. Can someone confirm that Dura Ace 9000 has the same cable pull ratio as 6800/5700? Like I said - this wasn't the case with 10 speed 7900.
BikeAnon
by BikeAnon
Dura Ace 9000 can be used with Ultegra or 105 11 speed.
I am running Dura Ace 9000 with Ultegra 6800 derailleurs. If I had 105 derailleurs, I probably couldn't tell the difference.
My vote is best shifters, down-level derailleurs.
zucchiniboy
by zucchiniboy
Looks like the consensus is looking extremely clear here - go for the DA shifters.
headwind816 wrote:I would match FD with shifter although no citations to support this action; a cheaper RD would put more $$ in your pocket to spend towards wheels.
Good suggestion - I think with my budget I can make the DA 9000 front derailleur fit too, then save the rest for the wheels.
istigatrice wrote:Arts cyclery actually have a pretty useful post on this topic.
Thanks - I read that article and seems like the input here fits with theirs.
mimason wrote:#3 Ultegra all around. Boom!
I've thought about that as well, but for some reason I prefer the black aesthetic of 105/Dura Ace over the grey on Ultegra. I know, maybe a weird reason...might change my mind though at some point.
I just double-checked the Shimano compatibility chart, and it shows full compatibility for shifters and derailleurs across 9000, 6800, and 5800.
http://productinfo.shimano.com/download/pdf/com/1.0/en
Thanks all for weighing in, this has been very helpful!
