New Vittoria Corsa G+in black?
Did the 1st bead go on without problems?
If yes, problems with the 2nd one are due to improper mounting method.
nope, 1st bead wasn't easy at all.
I found them quite easy on Bora, Reynolds Attack and Zipp 202. On 202s I didn't need even need a lever to remove them. Didn't need a lever on any for the install.
jwp75 wrote:thanks MS. I guess I'll be sticking to the 23s then. I hate how little clearance there is on the dogma....
Is your Dogma an F8 or a 65.1 that you are having clearance issues with 25c tires?
It's all downhill from here, except for the uphills.
Hi Fogman, it's an F8. Right now I'm running the corsa III open tubulars on Enve 4.5 and I have approximately 3-4 mm of top clearance. I do know that when I ride over loose gravel, sometimes the smaller rocks get wedged between the tire and brake bridge. I wish that they had designed a little more clearance.
- ultimobici
- in the industry
- Contact:
Enjoy!
- ultimobici
- in the industry
- Contact:
Well the Graphenes were stellar today. No slipping around on the sterrata or in the mud. No punctures either.
- ultimobici
- in the industry
- Contact:
Dr.Dos wrote:After the lovely tan stuff, I recieved a pair of all (full) black test tires.
Allegedly tri-stuff, black-box testing.
Which model do you have? Corsa are not made in full black
Rode 65 km's on te corsas saturday, found them quite slippy when cornering.
Rode 110 km's on them sunday, gotten more confident in the corners, but already a puncture in the rear after +- 8k
i have no idea: i took a corner, there where some loose tiny stone's on the road...
After that corner the innertube was pinched.
- ultimobici
- in the industry
- Contact:
Interesting. I rode 22km on sterrata with no issues. Maybe there was glass too?
ultimobici wrote:Dr.Dos wrote:After the lovely tan stuff, I recieved a pair of all (full) black test tires.
It's a prototype.
Maybe the color is due to the fact that tri-people are generally not coming from a classic cycling background and the retro visuals detract people from buying.
- ultimobici
- in the industry
- Contact:
Odd. Corsas are already shipping in anthracite.
