Covering holes in frame after going etap
So, my frame is an Di2 ready frame. I am going Etap and want to cover these small holes with some sort of plastic "fillings" which won't rattle out when riding.
Any suggestions? I am riding the 2016 Canyon Ultimate SLX. Thanks
shimano has small plastic covers to sell...very cheap..
allencanna wrote:shimano has small plastic covers to sell...very cheap..
Do you have a link?
Tape on the in- or outside is a no-go!
These: http://www.pushys.com.au/sm-gm01-rubber ... -4pcs.html
... Just with a flat top with no wire-holes. Can these be found?
if you mean the Di2 grommet I don't think it's what he's looking for since it won't cover the hole, I would say that it would emphasize the hole.
I'll second sugru.
Sent from my SM-G900F using Tapatalk
mariovalentim wrote:allencanna wrote:shimano has small plastic covers to sell...very cheap..
You're right!
My Argon actually came with rubber stoppers to fill the holes should I go with Di2. I think it is set up for the wires to enter through the front brake port.
I would think more manufacturers would start doing this in the future.
https://www.google.com/search?q=rubber+ ... Ay4QsAQIIg
or maybe
Specialized Part # S122000007 (CBS DI2 RUBBER PLUG STOPPER FOR CLOSING UNUSED WIRE HOLES)
or maybe
- spookyload
Or maybe just a small bit of electrical finishing tape that matches. This is weight weenies right? Cut it so it looks decent and it will look just like those plugs at a fraction of the weight.
If you hunt around in the stationary shops/sections, there is a black version of BlueTac.
It will fit your requirements. Super easy to use, completely clean when removed and doesn't affect paint
I use the much older, original light blue version (that has been around for over 2 decades) for attaching my cadence magnet behind the crankarm.
