jeffy wrote:looking into Sugru.
It is easily removable rubber when no longer needed, but solid.
Covering holes in frame after going etap
Surge, been using it on my camera for over a year, made my buttons much better and bigger. Everyone likes it bigger :0
https://500px.com/dallat75 : My images :0
toblu wrote:I neded the same for my Trek.
Seems like Trek now sell the plugs that firs my Emonda. I have made an order but havvent got them yet.
Have you been i contact with Canyon?
I have... They were not very helpfull, although they have made plugs for their pro-teams.
Just ordered the Surgu... Hopefully this will cover my needs.
Simple solution for covering the hole for external battery
I am also going for the Sugru solution. Seems an easy and, more importantly, clean solution.
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
Kayrehn wrote:I'll second sugru.
Amen. Sugru.
I stick a piece of 3M tape that's used for frame surface protection over it because that's a pretty big area to cover. Sugru works great for small holes thoughmrtkcmz wrote:An old topic but anyone using sugru after removing the bottom bracket gear cable guide? Did you remove the guide completely? And how you cover it with sugru or anything else?
Super late response but I use these: https://www.ebay.com/itm/6-Rubber-Gromm ... SwpDdU4UG7
Had to cut the bottom (non visible) part to fit it in some of the holes but they've not fallen off after a year and 5000+ miles in every condition.
