Alternative to Garmin GSC-10?
solarider
by solarider
I am trying to locate a couple of Garmin GSC-10 sensors to buy.
Seems that they were discontinued and replaced a while back.
Garmin now do a set which involves mounting a more bulky inertia unit to your cranks and a separate inertia unit to your front hub, which I don't like. I much prefer a single chainstay mounted device like the GSC-10 where you can attach a tiny rare earth magnet to the pedal spindle to trigger cadence and use one sensor for both speed and cadence. Much less obtrusive.
Does anybody know of a similar unit to the GSC-10 from any other manufacturer that talks nicely to a Garmin?
VPR
by VPR
kkibbler
by kkibbler
Wahoo Blue SCv2
crankinstein
by crankinstein
Bontrager makes a unit that is compatible, easy to set up and flawless.
Sent from my SM-N910W8 using Tapatalk
dmulligan
by dmulligan
Wahoo makes one that is both ANT+ and Bluetooth compatible.
Although I only use ANT+ right now I feel that buying sensors that are compatible to both is more future proof.
Sent from my Oneplus One using Tapatalk
Dodger747
by Dodger747
The newer Garmin sensors are a much more refined product than the old GSC-10.
Much less noticable that the ugly chainstay thing of previous.
Calnago
In Memoriam
by Calnago
I kinda still prefer the looks of the GSC-10 on the chainstay versus strapping that new brick of a speed sensor to an otherwise gorgeous hub. But they do seem pretty convenient for sure.
jekyll man
by jekyll man
Powertap and decathlon both do a dual sensor, but its not a single unit, its 2, joined by a cable.
Official cafe stop tester
zev
by zev
If you put the new sensors on your rear hub is there any evidence of aero drag?
