Do Aero Road Bars look ok on Non Aero frames
Aero Road bars on Non Aero frames
Looks cool, and it will be aero.
74
68%
Looks daft, don't build a frankenbike.
35
32%
Total votes: 109
53x12
by 53x12
I have not seen nor heard that for any road bike. You have a source for that?
Marin
by Marin
Umm no but it's kinda obvious isn't it?
53x12
by 53x12
Marin wrote:Umm no but it's kinda obvious isn't it?
No. If it was obvious, there should be some data out there to support it. No?
Regardless, a cylinder, an ellipse are all less efficient that an aero optimized shape.
Calnago
In Memoriam
by Calnago
If you're just talking abut the shape, then @Marin is right, it's obvious. If you can't visualize it, take a cardboard cylinder from a toilet paper roll or roll of whatever. Place it at an angle similar to the downtube of bike and cut it straight across level (same way a straight on headwind would be traveling). Look at the cross section of the cut area, trace it out on paper if you have to. What shape have you got?
Not as aero as a truly optimized aero shape but not bad either.
53x12
by 53x12
I'm not talking what shape you get with a cylinder downtube. What I am talking about is aero aspect of it. Wind and CdA behaves differently than one thinks. Eye wind tunnel isn't always calibrated correctly. Like why a kammtail behaves differently than one would think by just looking at it.
Derf
by Derf
53x12--as the very guy harping on focusing on low yaw, you've got to be able to see that a downtube is going to be projecting an ellipse into a headwind. I mean, geometry an all? Sure, we can talk about all the other tubes on the bike, but at least the DT is going to sorta be elliptical.
Anyhow, when I made my comment about skinny tubes and aero road bars, I was talking aesthetics--chunky tubes with thicker profile handlebars doesn't make me bat an eye. Fully agree with faster is faster and all. :)
P.S. Think there's a Specialized "win tunnel" video where they do compare a venge vs a 90's steel allez.
Marin
by Marin
Derf wrote:Think there's a Specialized "win tunnel" video where they do compare a venge vs a 90's steel allez.
Yes I saw that, but it's flawed in some important way IIRC, don't remember why.
Krackor
by Krackor
Derf wrote:53x12--as the very guy harping on focusing on low yaw, you've got to be able to see that a downtube is going to be projecting an ellipse into a headwind.
But aerodynamics don't happen in 2D planes. They happen in 3D space. You're going to get some air flow down towards the bottom bracket due to the slope of the down tube. That's different than a straight vertical elliptical tube passing through the air, and could potentially have a big difference on the aerodynamic drag.
wheelsONfire
by wheelsONfire
That test when they noted that different forks also has an impact on different wheels is pretty interesting.
Don't know where the link is, but it's another can of worms ;-)
Bikes:
Open *UP* (2016.04.14)
53x12
by 53x12
Derf wrote:53x12--as the very guy harping on focusing on low yaw, you've got to be able to see that a downtube is going to be projecting an ellipse into a headwind. I mean, geometry an all? Sure, we can talk about all the other tubes on the bike, but at least the DT is going to sorta be elliptical.
I'm just saying reality works differently than we think it will by just looking at it and passing it through our "eye windtunnel." As I noted above with the kamm tail example, shapes behave very differently in reality than we might expect by just looking at them. I haven't seen any real windtunnel data (visual of what air does around and after the tubes) for a regular small diameter steel frame. Yes there is the Specialized test with Venge vs steel Allez, but that doesn't show you what the air is doing due to air flow interaction. Even a CFD would be fine.
wheelsONfire
by wheelsONfire
What if an aero bike would be built without approval from UCI rules. It seems the UCI standard blocks out the real evolution.
Maybe this is not interesting to the masses?
Personally i would like to see a frame/ bike built for this purpose of just being aero with no UCI stamp of approval.
Bikes:
Calnago
In Memoriam
by Calnago
^That's what dedicated "tri" bikes are, like the UCI "legal" Shiv vs the "illegal" Shiv for triathlons, which is not subject to UCI rules. Actually, I don't even know if they still make the two versions anymore, but that would be the discipline you'd see that in since that is really where the "masses" for aero reside at this point.
wheelsONfire
by wheelsONfire
I was told the fastest bike ever is Pinarello Bolide. But i am not a TT guy. Actually i would sway more towards road, gravel and trail.
It would be very interesting to ride a bike made to be as aero as it gets with no restrictions.
I kind of have a hard time looking at microscopic benefits when i know the UCI rules are hindering many things (it's what i was told anyway)!
Bikes:
Lelandjt
by Lelandjt
I just got my 40cm Easton EC90 Aero handlebars. They look great and feel pretty nice in all the positions. Hands on the tops climbing doesn't feel too awkward like I've heard the Cervelo does. They have a much shallower drop than my past bars but since I'll set them up for my drop position that'll make me lower and more aero when on the hoods or tops.
