wilwil
by wilwil on Mon Feb 08, 2016 11:41 pm
Ive built two C60s for friends using Super Record dual pivot and on both the rear brakes feels mushy. I can hear the cable rubbing in the top tube. Is there any known cure for this?
DrJeffers
by DrJeffers on Tue Feb 09, 2016 2:09 pm
Can't help you with the cure, but can confirm I don't have this issue on my C60, which suggests it's not inevitable. Mine is a 48s - perhaps some frame sizes have closer internal cable tolerances?
markyboy
by markyboy on Wed Feb 10, 2016 7:42 pm
DrJeffers wrote:Can't help you with the cure, but can confirm I don't have this issue on my C60, which suggests it's not inevitable. Mine is a 48s - perhaps some frame sizes have closer internal cable tolerances?
Snap, identical as this with no issues
Colnago arabesque campagnolo super record 12
Colnago c64
Cinelli zydeco grx di2
JohnnySea
by JohnnySea on Wed Feb 10, 2016 8:23 pm
I actually have this problem on my 52s.
I've had 3 separate mechanics re-fit new cables and although it has improved since the original fit it's still nowhere near as good as I'd expect it to be.
