Cannondale 2016 road lineup claimed weights list
So I researched this quite well and I couldn't find any comprehensive list about the claimed weights of the 2016 Cannondale road lineup. I contacted Cannondale and they were nice enough to give out the weight of every bike in the 2016 lineup. I think this is pretty awesome. So here is the list, maybe someone will find it useful later. The weights are for the 56cm framesets.
What I found very surprising is that the caad12 frameset should be very-very close to the non hi mod supersix. I guess that's mainly because of the updated caad12 fork. If you check out the ones with sram red, you can see a 40g claimed weight difference with almost exactly the same components.
Also worth to note the exceptional weight of the stock himods with cheap wheels.
CAAD12 BLACK INC. - 14.8lb (6.71kg)
CAAD12 DISC Dura Ace - 16.80lb (7.64kg)
CAAD12 RED -15.84lb (7.2kg)
CAAD12 DISC Ultegra 3 - 18.34lb (8.34kg)
CAAD12 Ultegra 3 - 16.5lb (7.5kg)
CAAD12 DISC 105 5 - 18.96lb (8.62kg)
CAAD12 105 5 - 17.71lb (8.05kg)
S6 EVO RED - 15.75lb (7.16kg)
S6 EVO Ultegra 3 - 16.5lb (7.5kg)
S6 EVO Ultegra 4 - 17.27lb (7.85kg)
S6 EVO 105 5 - 17.55lb (7.98kg)
S6 EVO Tiagra 6 - 19.096lb (8.68kg)
S6 EVO HM BLACK INC. - 12.76lb (5.8kg)
S6 EVO HM TEAM - 14.03lb (6.38kg)
S6 EVO HM Dura Ace 1 - 13.77lb (6.26kg)
S6 EVO HM Dura Ace 2 - 14.47lb (6.58kg)
S6 EVO HM Ultegra - 15.22lb (6.92kg)
For the exact component list you can check out cannondale's website.
- prendrefeu
- Contact:
Claimed weights are rather pointless, particularly when there is no size designation.
Actual weights are actually useful.
BikeRadar actually weighed the 2016 line up back in July- http://www.bikerumor.com/2015/07/09/2016-cannondale-supersix-evo-caad12-road-bike-lineup-actual-weights/
njyeti wrote:BikeRadar actually weighed the 2016 line up back in July- http://www.bikerumor.com/2015/07/09/2016-cannondale-supersix-evo-caad12-road-bike-lineup-actual-weights/
Yeah, I found this post, but they did NOT weight the non hi-mod evo. Also they skipped the sram red caad12. But thanks for linking it, it's perfect to get the connection between the claimed and actual weights.
prendrefeu wrote:Claimed weights are rather pointless, particularly when there is no size designation.
I agree, but it's a good starting point when there is no actual data available. They stated that these are for size 56. Combined the claimed weight with some actual weight (like the one in your amazing post) can give some perspective for different sizes and models.
CAAD12 is astonishingly light. Given it is more expensive than some of carbon bikes in the market, I won't choose it over carbon machines.. tho.
Legend HT 9.5 RED 22
Colnago C60 Super Record
S-Works Tarmac 2016 eTap
S-Works Tarmac 2015 DA
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Spesh Venge Elite 105
Cervelo R3 2015 UT
Cervelo S2 2014 UT
Thanks for this!
