Sram Red 22 chainring gap between arm and big ring
RyanH
by RyanH
I could have sworn I saw a thread on here before about this but couldn't find it.
The new 22 red crankset has the hidden bolt nut in the arm. I just noticed that my chainring is bowed inward since there seems to be a gap. I put a pedal washer in there for now, but am I missing something? Anyone else run into this issue?
Sent from my VS986 using Tapatalk
ergott
by ergott
Pic?
That chain catching pin isn't supposed to be long enough to touch the arm.
prendrefeu
by prendrefeu
I think a picture would be helpful.
Did you install the chainring with the spacer on that hidden bolt? Or did you leave it off?
RyanH
by RyanH
I'll get a picture tomorrow. It's: [crank arm w/ female threads] | [~1mm gap] | [big chainring] | [2 or 3mm spacer] | [little ring]
kevhogaz
by kevhogaz
There should be no gap at all. My hidden bolt is just as solid as the non hidden regular bolts. You did something wrong, that we'll probably see when you post a pic.
RyanH
by RyanH
Is it possible that the Fibre-Lyte rings are not thick enough?
Marin
by Marin
You could have mentioned you have aftermarket rings on the crank :)
With the hidden bolt you'll have to spacer some rings with washers to keep them flat. Some rings even come with washers in the right thickness - my Dovals e.g. did.
deek
by deek
SRAM rings are 4mm thick there. If your ring is not 4mm thick then you will have a gap since both sides of the ring mount to the arm.
Sent from my Nexus 5X using Tapatalk
RyanH
by RyanH
Ya, I suppose that would have helped. So, where can I get spacers? I tried googling but no luck.
Marin
by Marin
Lathe shop maybe?
Or get some chainring bolt washers?
prendrefeu
by prendrefeu
