Hi All
I have just purchased a Sworks SL4 Frame new i have been advised it mechanical only but i have a new Ultegra Di2 groupset in box which i would like to fit.
Can some tell me if it is possible to fit the the Di2 to the frame?
As well i have a power2max Rotor 3d+ crack and want to know what type of BB it would take.
Thanks in advance. I have not received the frame yet so can check anything.
Sworks Tarmac SL4 & Di2
If it's an SL4 di2 should fit just fine inside of it - I ran di2 inside of mine without issue completely internal. Nothing unusual about the routing.
Simply ran the cables into the junction box I had placed in the down tube via the bottom entry under the frame. There should be a plastic cover that came to cover that slot instead of mechanical as well.
Just ride ..
My wife's 2013 Amira SL4 is set up for internal Di2 cabling - basically the same bike as the Tarmac. But, I believe the battery is still external. If I remember correctly, there is a little plastic cap on the top of the downtube to connect to the battery that mounts under the bottle cage.
