Spacers with small outer diameter?
jih, you run that on your bike? The fork appears to be cut significantly below the top of the stem.
AJS914 wrote:jih, you run that on your bike? The fork appears to be cut significantly below the top of the stem.
This was my first attempt. It is within the min insertion of the stem but I wasn't happy with it being inserted so shallowly so I made a shorter one as a 'final' version.
They aren't decals so I'm sure they are under. They are less subtle than they appear in the pics. In any case, it would be simple to sand them and respray them with clear if you wanted.
Weights posted for Point 1 Racing aluminum spacers vs. FSA carbon spacers: http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=137567
Two wheelers rock!
jih wrote:This annoyed me too so I made an integrated spacer and bearing cover on a 3d printer.
The forum won't let me post a link because I just registered. But to see, on youtube go to: /watch?v=456tLuolBmM
WOW you rock!, great vid
