Internal cable routing safety concern? (bike specific)
CPongpanich
by CPongpanich
Recently I found a picture of a disc brake road/gravel bike from a very popular 'b-grade' brand in Asia called Java. It has a carbon fibre fork and internal cable routing for the front disc brake. However, it looks like some one just cut a hole in the fork and routed the cable through which, I think, looks very ridiculous and unfinished. I asked the original poster whether this comes as a default from the factory and make sure if he didn't do it himself. He confirmed that it comes straight out of the factory.
To me it looks like the structural rigidity of the carbon fibre and fork might be compromised. However, I'm not an expert or very knowledgable in this area. Please, note that I have no interest in buying this bike, just curious with the structural rigidity and safety issue relating to this.
What do you think?
This is the picture of the fork and where the cable is routed through.
This is the entire bike.
Thanks,
Chanon
Marin
by Marin
Nice bike. I don't see why the routing should be more of a problem than on handlebars or frames.
CPongpanich
by CPongpanich
@Marin I think that the hole in the fork is not rounded properly, there are still a lot of variations on the edge of the hole. To me, it also seems like there is no extra layer of carbon added to the area around the hole to counter the missing material.
Chanon
Marin
by Marin
Yes, looks just like in my 2 bars with internal routing.
fromtrektocolnago
by fromtrektocolnago
Seven Cycles refuses to do internal cable routing or anodizing for that matte claiming it compromises frame integrity. That said virtually everyone else does it. Properly done I see no issue. Unless the former owner drilled his own holes you should be fine. It sounds like you think this was the case, so walk from the purchase.
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Colnago C-64 disc(ultegra) with Bora 35 wheels
rpenmanparker
by rpenmanparker
Frame integrity is about design. Sure you could have a problem if you take a frame (or fork) that is designed to not be drilled, and then you drill it. But that is not tha case here, or so we are led to believe. If the drilling (or molding) of the hole were included in the finite element analysis-computer aided design of the fork, why shouldn't it be suitably durable?
Robert
Marin
by Marin
The problem with internal routing is that it's annoying and heavy, not that it's unsafe.
Do you think bottle bosses, drain holes or fender mounts are a structural problem?
CPongpanich
by CPongpanich
Thank you for all responses. rpenmanparker summed it up nicely about the frame integrity. I am in doubt because this brand is a b-grade, I believe, Chinese brand which led me into questioning if the fork has been properly designed and manufactured to accommodate that hole.
I have no interest in buying and do not have any relationship with this brand whatsoever, I was just curious about carbon bike design and manufacturing.
Cheers,
Chanon
