eebrakes installation issue
tomso
by tomso
Hi there!
My new rear eebrake seems not fit with the dogma f8 as the top lever hitting the frame (44cm frame... very small). Anyone knows how to fix this issue?
Million thanks.
Tom (from HK)
kode54
by kode54
hard to tell from the pic. its possible to put a spacer on the bolt to move it away from the seat post where i think it hits. also, once you have the cable in and adjusted, i don't think the lever goes that high to even touch the frame.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
Delorre
by Delorre
tomso wrote:Hi there!
Million thanks.
Tom (from HK)
See : viewtopic.php?f=10&t=134573&hilit=wiggo
Same issue as you, and no real solution to make it work correctly :(
wheelsONfire
by wheelsONfire
Million thanks.
Tom (from HK)
Hi Tom,
i would contact Craig directly. He is very nice and responds very quickly. If anyone can help you make this work at it's best, or at all, i think Craig is your man.
Send him pictures and explain and i am sure he will look in to it for you.
Be kind let us know how it goes ;-)
I keep my thumbs in the meanwhile...
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
tomso
by tomso
HI all,
Thanks for all the input but sadly I have chosen to get refund. I think eebrakes will never fit a small frame dogma...
RichieE46
by RichieE46
Any solutions found? I literally was about to bite the bullet and purchase the brakes tomorrow for my 46.5 F8 frame and stumbled upon this thread. Thanks WW forum!
Sent from my SAMSUNG-SM-N920A using Tapatalk
fh8425
by fh8425
RichieE46 wrote:Any solutions found? I literally was about to bite the bullet and purchase the brakes tomorrow for my 46.5 F8 frame and stumbled upon this thread. Thanks WW forum!
I did a search on this, and it seems it will not fit even a size 47 so i guess 46.5 is out.
viewtopic.php?t=134573&start=15
I have ordered one and hopefully i can cancel it. sigh....
jrmynthn
by jrmynthn
I would encourage anyone to contact Craig from EE with any questions. I had an install question and he got back to me quickly and politely. Very helpful customer experience.
itguy
by itguy
jrmynthn wrote:
Thu May 12, 2016 4:26 pm
What's Craig's contact?
motorthings
by motorthings
it was Craig@eecycleworks.com last I contacted him
Bridgeman
by Bridgeman
I have a set of EEbrakes due to be mounted on my 56cm F10. I hope it works!
beanbiken
by beanbiken
Bridgeman wrote:
Wed Jan 10, 2018 5:05 pm
Would not expect a problem. I have them on a F8 50 cm. I would suggest segmented cable at least for the rear, easier to tune for length.
BB
Ahhh, coffee & carbon
PinaF8
by PinaF8
Any frame smaller than 50cm EEbrakes will not fit.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
