Quick question on stack & reach between two bikes
grnrcr
by grnrcr
Take a look at the two bikes below. Why do they have almost identical stacks when bike A has a taller HT by 15mm?
Bike A
HT: 17.5
HTA: 73*
TT: 56.5
STA: 73*
BB drop: 6.6
Stack: 57.5
Reach: 39
Bike B
HT: 16
HTA: 73*
TT: 56
STA: 73*
BB drop: 7.0
Stack: 57.4
Reach: 38.5
Tenlegs
by Tenlegs
The fork length (axle to crown) would probably account for most of it
hornedfrog
by hornedfrog
BB drop homie...
fa63
by fa63
Probably the combination of the two factors mentioned above.
cyclenutnz
by cyclenutnz
Aside from the valid points already made. Some manufacturers are not very good at calculating reach and stack.
There are a lot of brands where I have to check their calcs before importing into my database (including some of the big brands)
Tenlegs
by Tenlegs
BB only 4mm diff, what frames are they?
grnrcr
by grnrcr
Bike A is Helium SL. Bike B is Bura SL.
Tenlegs
by Tenlegs
Neil pryde Bura size L Vs Ridley Helium SL in M = very similar geometry, medium NP bura has a much lower stack
wingguy
by wingguy
look at the side on shots of the bike, the fork crown on the Ridley is almost down to the brake bolt, on the Bura it's a lot further above. So while the HT on the Bura is significantly shorter it has a lower BB and a taller fork. Which is why stack is a better measurement for comparisons.
Also cyclenutz - who's bad at calculating stack and reach - and what do you actually mean by calculating? It should be a pretty basic physical measurement, but a difficult to impossible calculation from a traditional geo chart.
grnrcr
by grnrcr
I see it now. Thanks a lot.
