Lightweight Meilenstein freehub removal
liam7020
by liam7020
One of my cycling mates owns a Lightweight Meilenstein tubular wheelset. He wants to remove the existing Shimano 11 speed compatible freehub and replace it with a Campag version. Am I right in thinking Lightweight use DT Swiss internals, so what’s the correct procedure for freehub removal here? He’s ask me for help but I want to be sure of the correct removal method before delving head-long into an expensive wheelset! Any special tools required? Cheers.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
toiyuet
by toiyuet
danbjpa
by danbjpa
here's a video
source
2old4this
by 2old4this
I use a simpler way (I think.)
- Insert a 1.5-2 mm hex driver from the drive side
- Insert skewer from the non-drive side (it will obviously not go through the whole way. The hex driver will block its way.)
- While holding the hex driver, lightly tap the skewer with your palm from the other side.
That's all there is to it...
liam7020
by liam7020
Thanks for the info guys. Feel a bit more informed now!
